42 minutes ago, Almboss said:
I was thinking of buying a pair and color matching them, not sure if it would be noticeable since my truck is Tungsten Metallic. Was wondering how much those cargo lights put out since they cant reflect to much off the flat black.
I had LED bulbs in my OEM housing and switched the light to this and this puts more light out than my stock, might’ve been the bulbs I was using before but definitely notice a difference for sure
On 11/20/2017 at 6:13 PM, Brandon Prasad said:
Just installed a new third brake light on my 2017 Sierra 1500 6E315A71-2390-4452-AF84-57928C317B49.thumb.jpeg.3e3d4012769c9ef11d582be902222708.jpeg2B0A0D53-7870-45A1-8AE3-C5DEDB325B34.thumb.jpeg.179d0778ca36fa32a9d0741b01c3d7c7.jpeg
Make sure you get a good seal. I got the same style but with smoked lens, and I had a feeling the gasket was a bit thin. Turns out I was right, washed the truck and went to get my rags from under the seat and noticed seat was wet. "I didn't leave any windows down??" And saw the top was wet and the rear window, and finally the headliner. JOY.
Took it off and I saw where the plastic was rubbing on the paint. Ended up taking the beefier seal that was on the stock 3rd light and slapped it on. But being genital with tightening it down, I found out the plastic (on mine) is a bit weak and snapped right under the screw.
Love my light though!!
Just quoting because I laughed at the autocorrect.
I used windex then thinned isopropyl alcohol when I installed my 3rd so the new seal would get a good stick.
Yup I just took mine off today cause it cracked on the right side where the screw goes so I’m applying clear epoxy/glue to seal the small crack up cause it’s seeping in water  , let the inside dry out, reseal all around the edges and put it back on tomorrow, this Canadian winter will put it to the test see how long it lasts
This was done last week, but video completed today.  Enjoy!
  • Like 5
I saw that too and laughed at the autocorrect. My iPhone used to autocorrect "Lardass" to "Kardashian." That was a great one!
Gotta get a good seal when you're working with a genital =)...OK, so I stretched the OP a bit.
On a more serious note, the 3rd brake light, XM/onstar shark fin, and seal around the windshield seem to be giving quite a few people some leak problems. I'm about to seal the shark fin with silicone or something just around the outside and the small hole in the back. Does anyone know if that's a bad idea for some odd reason? Is the small hole there for a reason?
Goes to show, proof read. Lol!
So it happened to you. Burley guys got to watch out.
I don't see anything wrong. Aside from my spelling blunder lol. I used silicone over the screws on my 3rd light.
Installed the Husky Splash Guards. Very easy instal. Opted to drill the optional hold on the rears rather than the tape and spring clip. Look great.
Used it as a truck today. Went out hunting with my uncle. He got a small doe. And that’s a case and a half of Point beer behind it. b20c5f0f85afc11a6b36b734ba55ebb3.jpg
Decided to color match the grille shroud just to see how I like it. Plasti dipped it first then used some dupli-color perfect match on top of that. Now I can just peel it off if I feel like it but I like it so I’m goin to have it professionally painted eventually.
Finally made a decision on which off-road bumper to go with a few weeks ago during a huge sale from Road Armor and decided to go with their brand new Sahara model with winch plate. I think my favorite part of this bumper is that they rate it for 12K lb winches for our trucks and declare the shackle mounts as tow points. Only company I've talked to that actually declares that shackle mounts as useful tow points. Couldn't be happier with the outcome. I'll post better pictures soon. Hopefully will be able to order a 12.5K Tuff Stuff winch soon if they ever come back in stock
5259FB48-A8C1-43B5-9A63-B7F9D083606F_zps
07084EEC-4F7C-467B-8854-AB94AAE827EC_zps
Edited by Mike1220
forgot some info and pictures
Picked these parts up from the painter. Can’t wait to finally finish this upgrade. Headlights will be installed this weekend. Grille in about a month.
    • How many miles were on the truck when you bought it and was there some form of oil change history generated through a dealer or an independent shop although not much would show up if the owner had changed their own oil. Just curious if it was a maintenance issue or if there was something off from the start, surely one would think the original owner would have realized it was using a lot of oil, its hard to go back in time and find out the true story of mysteries like this. Well hopefully the warranty company will go for it and just install a new engine, that would be the ideal outcome.    I still have so few miles on my truck as per not quite 9000 and will be changing the oil shortly which has around 2700 miles on it or so and its down so little on the dipstick from where it was at the beginning of this oil change that I could make the "claim" that it uses no oil but in reality would be a very small amount, less than a 1/16 of an inch. Just driving empty/not towing and easy driving so hard to say what it would do if it had a load behind it for oil consumption. So far very impressed with the very minimal oil usage.
    • I have a 2015 Silverado and sometimes I can not get in to the truck. I use the key to unlock the driver door. Something is locking the truck when I unlock it, last night I left the truck open and this morning it was locked with the mirrors folded in. This happens while driving so it is now a safety issue. I reach down for the folding button and they open, then they close again.  Any advice, thank you,   Ed
    • Did you ever find a resolution to this? my 2019 Silverado 1500 is showing the exact same headlights issues with the exact same symptoms.  would help a ton if anyone has any advice on this or better yet a known solution..
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
