1 hour ago, vonrokker said:
Can you show a pic of where you mounted the led light strips under the dash on both sides?
For the driver's side, I couldn't find a flat surface to mount the strip on, so I wrapped it around the A/C vent which gave it plenty of brightness. For the passenger side it stuck perfectly to the plastic cover below the glove box by the feet. You can only see the strip if you put your head down by the floor mat.
IMG_20180410_125937.thumb.jpg.0de326b0b003961fb507f3afa9ec4dde.jpgIMG_20180410_130026.thumb.jpg.b13bd1a65d1c8fc6d5e27156afd63568.jpg
Thanks!!!
i'm looking to do the led floor lighting. .but i want like a single style led .. instead of the strips.... dont get me wrong.. you did an awesome job!
quick question..... do you daisy chain the wires?... then go to the dome light?.. meaning.. each led strip has a black and red... .can you tie them all together then vampire tap to the grey dome wire?
something like these..  https://www.amazon.com/LEDMIRCY-Rock-Green-Kit-Waterproof/dp/B01MECII60/ref=lp_15736411_1_21?s=automotive&ie=UTF8&qid=1523389825&sr=1-21
not green.. possibly red..or white.
Edited by Crstfr
Just did the auto dim mirror swap!  Thanks to Phil, PGamboa, for the help and patience over the phone haha
I installed this thingy on the top of my 2017 6.2L. Not really sure what it does, but my truck goes really fast now.
  • Like 22
  • Haha 2
  • Confused 1
So close I can taste it
20180412_093544_HDR_Film120180412_093551_Film1
With the help of pgamboa’s thread about tow mirror upgrade I swapped the manual tow mirror for the power fold. And swapped out the amber running lamps for the smoked colored lenses.
I was one of the lucky few that all I had to do was change out the door switch and swap the mirrors since my truck came with the manual fold tow mirrors from the factory.
Where did you get those smoked lenses? Are they OEM or do they fit OEM?
I also swapped with pgamboa's wiring and couldn't be happier.
Boost Auto has them. They fit right in, newer model mirrors have different connectors so I had to get the pig tail wiring as well and do some soldering.
I looked at them. I considered buying. Good to know they have a good fit.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
