dieselfan1 Posted January 9, 2021 Posted January 9, 2021 My one bucket has no dirt in it.Both of yours do.Proven.Sent from my Pixel 3 using Tapatalk 1
Sean006 Posted January 9, 2021 Posted January 9, 2021 Have the iPhone 12 Pro Max and my truck has no wireless charging so did the mod to the armrest - (center lid indentation) bought the MagSafe charger and double sided tape - works great. 4 1
OffTheAir Posted January 10, 2021 Posted January 10, 2021 Got smacked by a rock on my way home today, made a really nasty chip right in the center of the passenger door. Good news is, this kickstarted a nice little winter project. Gonna get some touch up materials, fix that, and I'm also going to be tackling some small areas of surface rust I've discovered under the tailgate and driver door-jam. On a positive note, it's been precisely a year since I powder coated my chrome bumpers and replaced my OEM grill with a black one and no chips whatsoever! 1
JohnnyLane Posted January 10, 2021 Posted January 10, 2021 10 hours ago, Sean006 said: Have the iPhone 12 Pro Max and my truck has no wireless charging so did the mod to the armrest - (center lid indentation) bought the MagSafe charger and double sided tape - works great. Glad to see I’m not the only one after this setup. I did this to mine back in Nov, only I chose to conceal the cable through the rubber liner 90degrees down from the chargers output. I ran the wiring through the lid to a PD charger inside the center console that’s keyed to the ignition. I also 3m taped(w/ 3m adhesion promoter) for bonding, then added a trim ring to take away some of the “puck” look. Next time I have some clear coat mixed up I plan to paint the trim ring to match the plastic surround. To finish it off, I have a 3D textured 3m skin coming for the MagSafe charger that will match the leather of the console. I recommend the cplay2air module(I’ve got mine inside the glovebox) which will allow your CarPlay to work wirelessly while using this style setup. 4
Sean006 Posted January 10, 2021 Posted January 10, 2021 (edited) 7 hours ago, JohnnyLane said: Glad to see I’m not the only one after this setup. I did this to mine back in Nov, only I chose to conceal the cable through the rubber liner 90degrees down from the chargers output. I ran the wiring through the lid to a PD charger inside the center console that’s keyed to the ignition. I also 3m taped(w/ 3m adhesion promoter) for bonding, then added a trim ring to take away some of the “puck” look. Next time I have some clear coat mixed up I plan to paint the trim ring to match the plastic surround. To finish it off, I have a 3D textured 3m skin coming for the MagSafe charger that will match the leather of the console. I recommend the cplay2air module(I’ve got mine inside the glovebox) which will allow your CarPlay to work wirelessly while using this style setup. That looks way cleaner nice job Where did you find the trim ring ? the wire is already on my nerve so may update it soon Edited January 10, 2021 by Sean006
Snowcamo Posted January 10, 2021 Posted January 10, 2021 Preview. Coming along nicely. Will need to check fitment when installed.Sent from my LM-G820 using Tapatalk 2
JohnnyLane Posted January 11, 2021 Posted January 11, 2021 9 hours ago, Sean006 said: That looks way cleaner nice job Where did you find the trim ring ? the wire is already on my nerve so may update it soon Trim ring is from spigen.com. Black Friday deals had em for $10/ea. 1
PAPER Posted January 11, 2021 Posted January 11, 2021 12 hours ago, Sean006 said: That looks way cleaner nice job Where did you find the trim ring ? the wire is already on my nerve so may update it soon $14.99 on Amazon https://www.amazon.com/Spigen-Designed-MagSafe-Charger-Included/dp/B08LP8PSX7/ref=sr_1_1?dchild=1&keywords=magsafe+mag+fit&qid=1610334561&sr=8-1 1
boettcher40 Posted January 11, 2021 Posted January 11, 2021 On 1/8/2021 at 9:40 PM, dieselfan1 said: My one bucket has no dirt in it. Both of yours do. Proven. Sent from my Pixel 3 using Tapatalk Cyclone dirt traps from CG do wonders!
Frankielozano214 Posted January 11, 2021 Posted January 11, 2021 (edited) Got my new REKLEZ uca’s installed, look good. But they didn’t set the struts to 9” so I gotta go back and have the adjust them! new McGaughy struts Reklez uca’s need to move up not at the 9” mark no way you can have a 7” lift with 37’s Edited January 11, 2021 by Frankielozano214 2
PAPER Posted January 12, 2021 Posted January 12, 2021 On 1/10/2021 at 6:51 AM, Sean006 said: That looks way cleaner nice job Where did you find the trim ring ? the wire is already on my nerve so may update it soon If you decide you want to go wireless Android Auto or Apple carplay . here is the link to a plug & play item . I was told this is the Unit MVI use's without the $600 high mark up . https://phoenixautomotiveinc.com/products/touch-portable-apple-carplay-android-auto-plc-h6?variant=32634064961582 1
lildann Posted January 13, 2021 Posted January 13, 2021 If you decide you want to go wireless Android Auto or Apple carplay . here is the link to a plug & play item . I was told this is the Unit MVI use's without the $600 high mark up . https://phoenixautomotiveinc.com/products/touch-portable-apple-carplay-android-auto-plc-h6?variant=32634064961582This looks cool. Can you give me more info on this? Are you using stock radio and screen? I’ve got a 2014 with Bose and navigation and am having a hard time wanting to spend the $700 plus the downtime of sending in my instrument cluster to have it programmed to have the steering wheel buttons work. Any pics of it’s menu and it working? Sent from my iPhone using Tapatalk 1
PAPER Posted January 13, 2021 Posted January 13, 2021 (edited) 8 hours ago, lildann said: This looks cool. Can you give me more info on this? Are you using stock radio and screen? I’ve got a 2014 with Bose and navigation and am having a hard time wanting to spend the $700 plus the downtime of sending in my instrument cluster to have it programmed to have the steering wheel buttons work. Any pics of it’s menu and it working? Sent from my iPhone using Tapatalk Sorry I don't own the unit . I saw it recently in someones truck @ a car function . I noticed they were watching YouTube So I asked what he was using to stream . He showed me the little black box plugged in & went through a few features YouTube , Netflix , Google Play store . I asked him were he purchased it & he gave me the link & he also said it was the same unit MVI uses & is selling for $600 . But he got it for half that at the Link . Sorry forgot to mention his truck is a 2018 with Bose all stock besides rims . Not sure why you mention your steering wheel buttons ??? This wont help you getting them to function ... Edited January 13, 2021 by PAPER 1
slide187 Posted January 13, 2021 Posted January 13, 2021 This looks cool. Can you give me more info on this? Are you using stock radio and screen? I’ve got a 2014 with Bose and navigation and am having a hard time wanting to spend the $700 plus the downtime of sending in my instrument cluster to have it programmed to have the steering wheel buttons work. Any pics of it’s menu and it working? Sent from my iPhone using TapatalkThat unit does not work with the stock radios. It is made for one of the Android based after market replacements like the ones Phoenix makes. Sent from my iPhone using Tapatalk 1
Snowcamo Posted January 14, 2021 Posted January 14, 2021 (edited) Got it 99.9% finished sunday. Needs little tweak to the top layer. Sent from my LM-G820 using Tapatalk Edited January 14, 2021 by Snowcamo 2
