I'm on way to pick up said parts.
Thanks again
They look nice
Sent from my Pixel 3 using Tapatalk
Thanks again
They look nice
They are wayyyyy too nice for my truck! Straight trade for stock headers! Done deal!
  • Haha 1
PM'ing address now. Thanks for the update....
Didn’t wanna send it off looking ugly so I got some high heat prime and paint and laid some down for ya!
You all should take note, this is what customer service is all about!
Lighted Door Sill Plates,...Was too good of a deal to pass up... IMG_20210128_192500028_HDR.thumb.jpg.7064a96122eda9633b05dfd88b60ffec.jpg
Where’d you get yours from?
13 hours ago, Chevy8088 said:
Put on a RDJ tailgate panel
is that a stick on thing or ?
what brand mud flaps are those? and the wind deflectors? do they cut down on the wind coming in when the glass is down? these trucks are horribly designed in that manner, I had the windows down and the rear window open and had a soda can in the bed of the truck and that thing wiped around and shot inside at the dash like it shot out of a cannon. lol
I see them on ebay for around $250 a set usually, depending on the color I have seen sets selling for like $80 never black though of course.
Not a K2 mod, but today I made it easier to DO mods to my K2 in the winter!
  • Like 11
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
