..HDX step bars installed.. started a thread for anyone planning on installing these
20180928_175106.thumb.jpg.9c5982b0006cc1ee0eadf0bda5def3b1.jpg20180928_175116.thumb.jpg.bf3ac46b32281589906726febff8eb10.jpg
Thanks for the pics, they look very good. How long did they the wife take to install these.
I finally got new meat! The BFG tk02s were great and lasted over 60k miles. So far these Falken wild peak at3w’s have been great. I have noticed that they make much less noise than the BFG.
Any more pics? These look good, would love to see a full truck pic!
.. once I figured out how/where the brackets attached it was only about 10mins each side to install.. the first one was on and off 3 times until I was happy with it.. she wasnt impressed.:) I'll go back around tomorrow and add blue loctite to each fastener and I'll spray the underside/back of the bars with Krown/Rust Check/Fluid Film.. which ever I have laying around
Edited by STRMTRPR
Thank you, it’s getting dark but here is a quick shot in the driveway.
Where the heck have you been?! LOL! Nice shoes!
Those falkens in 285 seem to run bigger than other brands. They look about the same size as my 295s
They do look bigger, must be taller wall height. 285/65/20’s ?
Ones on the silver truck are 285/70/17, mine are 295/70/17 nitto G2
11 hours ago, 300 Blackout said:
Cover looks absolutely sweet! The sticker is cool too but would drive me nuts being off axis like that. Your truck is too sweet to settle. Buy a new sticker and line it up right. Your truck deserves it
Thanks man! And yeah 100% with you, new sticker was ordered same day I put it on, it will drive me nuts otherwise.
.."blacked out" the front orange signal lights with perforated black vinyl.. gives it the tinted look but still passes all the light thru..
Before and After:
  • Like 5
Before and After:
More & more stormtrooper-like.
Wash, clay bar, and polished.cb235a34e7a99cfcbfc424a7607fb5f9.jpge233d1917b79104cd95da8999f5d9914.jpg7deba07f530ed12dda153555252a4cef.jpg
Sent from my SAMSUNG-SM-G890A using Tapatalk
Yesterday, we cleaned out our storage locker (2 months behind schedule).  Last night, I adapted my list of mods from my ‘15 for what I want to do & going to do to my ‘18.   Removed the antenna earlier this week. Found my tow hitch brake light (broken frame) and My first one, going to see about making one complete one that only lights up when brakes are used.  The broken one uses both elements when lit, and my original one only uses the brake element.  Took the tail light out of them, and found a way with the second one to tie both elements together.  One day soon, the two shall become one and be installed on my truck.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,317 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
