So I wanted to give it a few days for everything to settle after installing the lift and wheels. Front fenders measure right at 40" and the rears are 40.5". The tires are pretty true to spec size wise, about 32.5" tall and 11.5" wide.
How do you like the ride and the noise? My Nitto G2s are horrible on a wet road...have you driven on wet streets yet?
When you are at full lock and hold it, what kind of clearance do you have around the liner, swaybar, and UCA?
Thanks....and nice truck, btw!!
Love the setup, and the look of the RT's! How bad is the rubbing?
not to horribly. My tires are 33x12.5 and they slightly rub sometimes while going foward at 26 degree turns. And in reverse they rub at 33 degrees but don't rub at full turn in either direction.
Nice man. Im trying to avoid rubbing, but geez those 20x10's look great. Going from an nnbs with a 9" lift, 35s and 20x12s to a leveled 2016 is really bugging me. Really hard not to just lift this one too.....
I'm looking to purchase a set of XD Heist rims in either a 20x10 or 20x9 size with 275/65/20 or 305/55/20. My biggest question is the offset selection is very limited for those rims. I am looking to have slightly outside the fenders stance. Which offset would be best for this look?
http://www.kmcwheels.com/wheelSpecs/4378/1675/20320/xd818-heist
Just as a frame of reference, my rims are 20x10 with a -19 offset. I have 305/55/20's as well, and as you can see they stick out but in my opinion just the right amount.
22" replica wheels on 37s
Where are you buying replicas from and do they have those wheels in 20's? also what offset are they? same as stock wheels or different? thanks bro.
22" GMC Accessory Wheels - Factory setup, probably my favourite 22" design!!
Edited by icecrm
Look on eBay, they are all over eBay. I forget the exact name of the company but they are legit and have outstanding replicas and definitely 20's as well
Edited by Abearclaw
I got them from a local shop but check out customoffset.com. They had the best prices I found on the Internet and free shipping. They make them in 20,22,24,26. With different offsets
Best setup for the Silverado 1500 leveled is Nitto TG 33x12.50r20 with 20x9 +1 offset Fuel Nutz check my last post for more
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
    • Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
    • Knowing the life of your brakes is a highly important status to keep track of. If you suspect your brake sensors need attention, please fill out our support form with additional details on your experience. When did you last take it in for inspection? Our team will follow up with next steps as soon as next available. Please include your username and GM Trucks Forum in the form as well. Support Form: https://s.chevy.com/support-request
