The 'official' GM fix for moisture in headlamp capsules is to perform a 'test' by leaving the headlamps on for -four- hours, if it dries out, no more repairs are necessary. If it does not dry out, they are to drill 'vent' holes in the housings, which 99% of the time works. If this does not solve the issue, then, and only then, are they to replace the housings.
Brought it to the attention of my dealer they didn't bat a eye and said they would order a cpl, we will see, either way I love my truck!
My truck is getting replacement for both later this week.
The problem is that the replacement ones will most likely be just as bad.
Edited by pm26
I just got rid of a 14' Silverado because of all the headaches and picked up a 2015 Sierra SLE and just noticed I have the moisture too. It's been between 35f and 0f the past few days. Right when I picked it up, they washed it and it was noticed when I got home. This makes me so fckn angry. If that's the least of my worries compared to the leaking, rattling, falling apart pos I just unloaded, I'll be happy. This is ridiculous though. I work for Subaru and some employees have projectors on their subies and don't have this problem. Hopefully this is fixed or goes away. This will most likely be the last time I give GM my money.
I've had my SLE since September 2013, and never once have mine fogged or had moisture in them. Knock on wood!
However, the headlights do suck for nighttime driving. Especially in the rain.
Edited by Ventilator
I had this when I bought mine last February...it lasted about a week. It seems to have "burned off" and knock on wood, it hasn't been back. I also read on here a guy purged his with nitrogen and it was gone instantly.
I noticed the moisture in mine the day I brought it home and was admiring the new truck. Mine have either quit fogging, or I just have gotten used to it and don't notice anymore lol.
I can see it now in the TSB.
"Step 1- put off helping customer as long as you can, they may eventually quit noticing the issue and/or get used to it and overlook the issue.
Thanks strike1st. This gives me some confidence it will go away. It is -20 with the windchill here, so it probably hasn't gotten warm enough to burn off the moisture.
Anyone experienced this problem; Headlamp housing condensation? If you have, did you're servicing GMC or Chevrolet Dealer replace it as a warranty item?
I woke up this morning to find my truck, '14 GMC K-1500 Sierra Denali in the garage with the left headlamp housing clouded up with condensation. No visible cracks, chips, scratches, etc., The right side lens remains clear....
Edited by Rewillia
So I own a 14 sierra sle and seeing as though in northern IL it went from -5 to 40F in about a week all the ice melted and I had a bunch of dirt and grim on my truck.
I took it through the car wash and drove home. When I got home I noticed there was fog on the bottom part of my headlight.
I'm not sure if it's because the headlight is warm and the cool air is causing this fog in the headlight or if I have some type of leak or something in the headlight.
Anyone else have this problem?
Thanks
Yep, mine were replaced a couple of weeks ago. The condensation hasn't returned since.
Edited by POS VETT
Please do some searching before posting. It is a wide spread issue.
If it doesn't go away then take it back to the dealer
It's not that I didn't do research I looked throughout the forums to see if anyone had posted about it and I could not find anything. I was just wondering if anyone was experiencing the same issue...
Take it in. My 2010 just started this.
Ryan
