Just got my 4600 front struts in (zero thought to ever level my truck, i think its silly) my rears were installed last fall.
Man what a difference from the ranchos. Much less harsh or brittle feeling. Much smoother and a better planted feel on turns ect
Prob going to be my plan also..
On 1/29/2015 at 5:32 AM, dcarl said:
I installed the 5100's in place of the Rancho's along with a Zone 2" leveling kit for the front and left the front shock at the stock setting because I'd read that with the 5100 at the highest setting (1.86"), some were saying the ride was pretty stiff. I can say the ride with the Bilstein's over the Rancho's is far superior. It's still firm but not harsh. I have not tried other settings on the front. I thought about taking out the 2" leveling kit and raising the shock up to the highest setting, but I'm happy with the ride and not sure I wan to do the work anytime soon. I have no regrets buying the Bilstein's though. They went on a truck that had less than a 1,000 miles and for the better ride it was worth the money.
I am interested in doing this as well, if I put the 5,100's on the front and back along with the 2" zone leveling kit, would i be able to adjust the back shocks so the truck still has a little rake and then it will level out when i am towing a boat?
There is no adjustment on the rear.  I'd suggest a set of air bags for the rear like Air Lift to adjust the rear when you have a load.  I have the Ride Control bags (2000 lbs) with a Wireless One Controller.  I tried the Load Lifter Ultimate (5000 lbs) with a Smart Air II Controller and it rode bad, so I swapped it out for the lighter system.  Other people have not had problems with the heavier spring but I'm happy with the lighter one and I tow a heavy 30' pontoon boat and a 16' enclosed trailer loaded with motorcycles and it does fine.
https://www.airliftcompany.com/vehicles/gmc/sierra-1500/2015/4-wheel-drive/?bed_style=69.3+in.%2F5+ft.+9.3+in.+Bed#l
On 3/12/2018 at 1:48 AM, jgraves13 said:
Okay so who's gonna be the guinea pig for the eibach system? :P
Just placed my order on the Eibachs... will report back when they are installed.
Looking forward to the report!
Bilstein 5100’s allegedly provide up to 2.5” of lift up front. Is this actually correct?
no..  but it is the best change I've done to this truck since I got it. The Rancho's are pure junk
It’s different on each make/model. On the GMs it’s:
0, .75”, 1.25”, 1.85”
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
    250.3k
    chfkief
    chfkief
  • Who's Online   4 Members, 0 Anonymous, 1,508 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
