11 hours ago, jimmyboy8301 said:
24238304
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
This is what the Bilstein site gave me for my '18.  Its what I ordered but have not installed yet.
Guys,
Without doing a lot of searching from my phone I was hoping someone could readily help me with a couple questions.
I’m planning to install a set of 5100’s on the front of my ‘16 crew Silverado 1500 (Auto Anything has them on sale) similar to what I did to my ‘14 GMC 1500 Crew. Problem was at the max height setting the rear then became a bit to low when I was done.
What size blocks do I need to maintain a slight rake and do I need new u bolts?
Any specific manuf. of these blocks you would recommend that may also come with the u bolts if necessary?
Thank you.
9 hours ago, Rob38jr said:
Guys,
Thank you.
I would think 2" blocks would be perfect for a little rake. I have the Bilsteins maxed and 3" blocks that gives me pretty much the factory rake or maybe a little more.
On 4/26/2018 at 1:13 PM, Rob38jr said:
Guys,
Thank you.
Depends on how much rake you want, but 2" should be sufficient.  I have 5100's all-around, with the front at full and a 2" RC block in the rear.
Front before: 36 1/4"
Front after: 38"
Rear before: 39"
Rear after: 39 7/8"
There's still almost 2"s of rake.
Front after: 38"
Rear before: 39"
Rear after: 39 7/8"
Thank you that sounds like just what I’m looking for.
Front after: 38"
Rear before: 39"
Rear after: 39 7/8"
Truck looks awesome by the way!
Hey guys, I had my bilstein 5100’s installed 2 weeks ago and the ride and look is great, but I’ve noticed a pop in the front end when turning at slow speeds. I notice it most when I’m at a complete stop and then crank the wheels and begin to turn slowly. I never had the noise before hand. I purchased and had them installed by 4 wheel parts... I took my truck in to them yesterday and of course I couldn’t get it to make the noise while in the parking lot for them to hear, so I made an appointment to have them fully inspect it this week. Has anyone else had this issue? I have the shocks set at the highest setting, but should I lower it down to the 3rd setting? Any help or recommendations would be highly appreciated!
I don't have the Bilsteins, so I don't have first hand knowledge of the pop, but I swear that I remember people talking about the low speed pop on this thread or another thread. I believe it was the top bolt not being tightened down all the way. Search the thread using the search box on the top right of this page.
My truck (SLT Crew Cab) had a similar low speed pop while stock. The dealership replaced or lubed the bushings and it was fine after that.
I installed the rear 5100's this weekend, along with some Firestone Ride-Rite air assist springs.  The rear feels so much more planted now, and much quicker to respond.  The front is still bouncy until I can get the new fronts installed.  Hopefully I will have time soon.
41388829074_3e16c4703c_k.jpgIMG_20180511_164206950 by Mike Kubiak, on Flickr
42108758441_1f212a03c9_k.jpgIMG_20180511_164047901 by Mike Kubiak, on Flickr
I'm sure the info that i'm looking is somewhere in the almost 100 page thread, so anyway just order the adjustable 5100s for my 2015 sierra 1500.  I'm looking for prior measurements and how much more lift you got from each position on the springs.
Sent from my Phone using Tapatalk
I read almost every page of this thread before putting on my Bilstein kit and want to thank everyone for the great information. I ended up setting mine on the third setting so I wouldn't squat so bad when towing. I still have a slight squat when towing my Jeep, but it's not bad. Here's a pic for reference for anyone who tows ocassionally like me.
Looks good!  If you want to get rid of the squat, the Firestone Ride-Rite assist air springs I put on mine are great (3 posts up)!  The kit was less than $400 and comes with everything you need.  I had the springs in and shocks replaced in about 1.5 hours.
I was looking at that when I posted earlier, that's a sweet setup! I think I'll be going that direction eventually.
    250.3k
    chfkief
    chfkief
  • Who's Online   2 Members, 0 Anonymous, 1,425 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
