Yeah, I guess I will just need to drive over to one of the local shops, there are a few good ones here, and let them inspect my truck and see what we can come up with.
I don't need a monster truck, but I wouldn't mind a little more lift and a little nicer ride on and off road.
On 10/2/2018 at 7:55 PM, parshal said:
I don't want a full 2" lift and am contemplating moving the fronts to the .75" or 1.25" setting and adding another inch to the rear.  I've seen numerous posts where the 1.25" setting is more like 1.5".  I've found two posts where the poster has theirs at the .75" setting.  One said it gave .75" and the other said 1".  If it's 1" I'll probably move to that setting.  I'd really like the 1.25" if that's what it really does.
To follow up on this for future searchers.  I moved the ring to the second setting from the bottom.  It yielded almost 1" of lift in the front.  If I had to be precise I'd say around 7/8" or a smidge more.
If I ordered 5100 Bilstein shocks on a vehicle that is stock, then later go to a 3 or 4 inch lift will the shocks have to be replaced?
On 3/25/2018 at 7:34 PM, tanner709 said:
It will essentially level the truck, with <1/2" difference at the fender height measured at the center of the wheels.
IMG 0350resize
Sorry to ask a stupid question but I'm new to this leveling stuff.  So all you did is install the Bilstein 5100's at max height 1.85?  It looks pretty levele to me.
All I want to do is level my 2018 crew cab Sierra.
Depends on the lift. BDS would replace, zone you could use bilstein up front. I'm not sure about others.
Rear shocks would have to be replaced.
I added 5100's this week. 3rd setting. Also 275/60r20 cooper AT3 4s tires. Like the setup.  Much better ride and handling compared to the stock Ranchos.
Factory Ranchos should be outlawed! LOL
Sooo....  If I have the stock Ranchos and a 2" level kit and 2 or 3" lift out back(axle blocks)...  Can I just get a better ride with new shocks?  Probably nothing too fancy and I don't need any more lift I guess, but if I can get a better quality ride on and off road by just bolting on some new shocks, what are the best bang for the buck for my setup?
From what I have read the Bilsteins are much better than the ranchos. Much...
I would find the lowest price online that you can, and have summit match it. That's what i did and landed about ~300 shipped for all 4 corners from summit. GL
Cool.  The problem will be getting them installed.  I need a lift and all that, because I assume I have to take the front strut off and apart?
Not necessarily... I did mine in my driveway, not on a lift. Yes, you pull and disassemble the shock/spring, but you can do that using a jack, jack stands, etc...
Same here. Did mine in the driveway with jack stands. Used a cheap spring compressor to move springs over. I had to unbolt my top ball joint too since my truck already had the RC spacer on it.  It was really pretty easy though.
    • Dealer just confirmed that GM is "out of AC compressors."  Not sure if all 2019 to 2026 trucks use the same compressor, but a shortage like that is hard to believe.
    • I think we're reaching the end of constant projects/work.   The water pump bolt appears to have self-sealed, as it's not leaking anymore. I'll take it, and, I'm ready should it self-unseal! I was also getting an oil leak at the front oil pan seal and timing cover and came to find a pan bolt on the corner wasn't even finger-tight. Too easy. And, it was. But, it appears tightening it has reduced a leak producing spots on the ground every time I parked, to just a weep, leaving an occasional dot on the cardboard that lives under it while parked. That's acceptable on a 30 year old engine in my book. I do hate leaks, but, replacing the pan seal is quite the job.   The rear washer line is reconnected and the sprayer works, although getting an intermittent washer fluid drip off the bottom. I think it's just residual...the reservoir filled up the channel in the rear floor and drained down into the upside-down spare tire/wheel. So there are residual puddles all over under there, will wait a few days for it to spill out and dry before I go chasing a potential leak.   The door speaker...no dice. Speaker works just fine, it's that channel in the factory amp that's gone bad. Can't win 'em all. And, whomever buys this will probably tear out the factory radio for something more modern anyway.   I put about 110 miles on it yesterday. Put a lot of wind and heat into it with some mountain driving. Still runs great. Near the top of the pass I got off on a gravel side road and put about 10 miles on with 4hi engaged. Works great.   If ya squint, she's mint! God I wish these were still in production. I can see why they're not. They're rudimentary bordering on agricultural. They began life as a pickup truck and then modern society demanded the rear be enclosed for kids and crap. They're still a pickup underneath, and that gives them lots of ride character, sway and bounce and bump steer. They're alive on the road, and, at least for purposes of nostalgia, it makes driving one a lot of fun.   The Check Engine light did come back on the pass, P0134 for the upstream O2 sensor dropping out. Putting heat into the exhaust causes it after about 10-15 seconds of increased load at higher RPM. The downstream sensor is completely mangled (someone clearly had a rough time removing it, but they didn't replace it?) so I'll just put two in it. For what, mostly to cure the CEL, I can tell the cat is damaged. It's not plugged or fractured, but it's not catalyzing. There's some guilt in not fixing it, but at a cost of $500+, the truck just won't get driven much under my watch. I dislike the smell...running the truck in the shop even with both doors open and the overhead fans blasting, I still reek of pre-cat exhaust. Sticks to clothing and everything else.   Window motor (I'm dreading this), and tires, and that should be about it. 50/50 on Starfire Solarus H/T's, or spending $20 more per tire and going with Cooper Discoverer RT's. I like the look of the RT's a lot more, but is it worth it? I've got a really good (just very old) Toyo Open Country XTX on there now and I like it.
    • From what I've seen, they "could" sell the switch but designed the assembly such that the switch can't be readily removed and replaced without removing a plastic locating pin.  Sure appears aimed at forcing the end user to purchase a $900 shifter assembly instead of a $20 switch.  Thankfully I still have some extended warranty left...  this one has had warranty repairs almost every 5K miles from the day I bought it.
    • I'm well aware of the typical bathtub failure curve, but plotted, this truck has been more like an elevated straight line.  It started days off the lot with misfires that GM couldn't solve for almost 2 years, and steadily continued over the last 5 years with repeat replacements of wiring harnesses, camera modules, cameras, parking sensors, head unit, rear windows, rear leaf springs and bushings, lower control arms, a radiator, and now an ac compressor and a column shift assembly.
