around $800 for the pair
Bilstein is late to the party.
The first introduction to these was back in 2015
Other vehicle kits are 650-700. I think once these are picked up at various places we will see a similar price.  Might take a month or so.
I've waited this long, I'll wait another couple of months to hopefully see lower prices. Everyday I'm shocked (sorry) at how poor the stock suspension is on my '15 SLT Max Tow 4x4.
AMAZING NEWS from BILSTEIN!!!
We have 130 sets of the new 6112 for the 14-18 Silverado and Sierra READY TO SHIP!! These will sell out by Saturday and be on backorder again for months! Dont miss out!
Our price is the best around!
GM-Trucks Members get yours here - http://battlebornoffroad.net/bilstein-new-products/bilstein-6112/47273702/i-7531506.aspx
SAVE $100!! Use code: GMTRUCKS
Edited by Battle Born Offroad
Right now you can get them for $600 shipped...
49 minutes ago, Yondu said:
Excited to read reviews of those going from 5100s to 6112s.
I noticed a big difference on my 2009, especially in the rough stuff! On road, there is less motion translated to the cab as the bigger shock is able to use less effort to control the bumps. I think on these heavier full size trucks, you really are best off with a 2.5" diameter shock or larger up front.
Which shock is recommended for the rear? I have a '15 Sierra Max Tow if it matters. 5160? I know it's in here somewhere but this is the downside of such a long thread. Thanks.
5160s or 5100s. 5160s are a tad longer and will allow you to run up to a 3" block, where as the 5100 is only good for a 2". Ride quality and valving is the same, but 5160s can take a bit more of a beating offroad without fading due to the reservoirs.
5160 Rear - 25-242515 - http://battlebornoffroad.net/bilstein/bilstein-truck-off-road-b8-5160-series-shocks/25242515/i-7476078.aspx
5100 Rear - 33-238319 - http://battlebornoffroad.net/bilstein/bilstein-truck-off-road-b8-5100-series-shocks/33238319/i-2157392.aspx
Be sure to add qty 2, and be sure to use the code: GMTRUCKS
So the block in the rear on the Rough Country 5" kit is a 3inch block. So do I need the 5160's ? I could've sworn I had seen tons of guys lifted who used the 5100's
If you are using the standard 0-1" 5100 for the 1500s and that block, you are limiting your travel by a bit. It will work, just realize the shock is being stressed at full droop pretty hard.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
