On 1/26/2015 at 4:18 AM, Spurshot said:
First, the 6112 is not available for the gm truck yet.
All 6112 models back in stock - orders from last year shipping first, direct from Bilstein. 150 units +/- are up for grabs
07-13 GM 1500 - http://mrtmotorsports.net/bilstein-shock-sets/bilstein-6112/47244641/i-7474058.aspx
14-18 GM 1500 - http://mrtmotorsports.net/bilstein-shock-sets/bilstein-6112/47273702/i-7474057.aspx
Gentlemen,
              I will be installing the 5100's tomorrow at the highest setting. I have 20x9.5 wheels -18 offset on 305/55/20's. I can't imagine it doesn't rub like hell. Wish me luck.
8 hours ago, z71skywalker said:
Gentlemen,
Please post pics...really interested in seeing.....thanks.
So I have "skimmed" through these 134 pages looking for the answer to one question that I am sure is here but cannot find.
 I have a set of 5100's with springs set at stock height that I want to install. Will I have to separate any ball joints, tie rods, sway bar, etc.?
I am under the assumption that getting the truck up on jack stands, removing the tires and putting the floor jack under the lower ball joint - 5 bolts (3 upper/ 2 lower) and I'm in and out with these.
When I did mine I had to remove the sway bar end links and also separate the upper ball joints to get the originals out and the new ones in.
Mine were set to stock height and I swapped the factory springs onto the new shocks.
thanks:sigh:
After the wheels are off you need to take out 2-10mm bolts that hold your brake line and abs line to the knuckle/uca. Then you're gonna have to remove sway bar end links on both sides to get the lower a-arms to drop. That should get you enough room.
Sent from my SM-G975U using Tapatalk
I can live with that, thanks
For my 2014 just had to remove sway bar end links. Used a small atv jack to push the lower shock mount up onto the bottom arm as it was about 1/2" longer.
Sent from my Moto Z2 Play using Tapatalk
On 4/5/2019 at 3:38 PM, z71skywalker said:
Gentlemen,
Any pics of how it came out?
Anyone receive or install 6112’s on their K2 yet? I am interested in a set but would like someone to be the guinea pig lol.
I ordered mine first thing in the morning on 3/28 after seeing that they were in-stock and still don't have them.  I was curious if anyone has received theirs yet as well.
    Bulldogger
    Bulldogger
  • Who's Online   4 Members, 2 Anonymous, 847 Guests (See full list)
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way to big should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crosing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
