Thought I’d add to the discussion since this post helped me out quite a bit.  Yes the Ranchos suck, and the 5100s are night and day difference.  2017 GMC Sierra All Terrain X Package (Z71 w exhaust).
Put 5100 Bilstein’s in the back - easy enough, came from the Jeep world, this was no problem.
Used a local shop to install the front struts, set to the max setting with a 0.5” spacer to fit a wide tire.  I was going for the most tire I could fit with the least amount of lift without using one of those level kits, and said a little prayer.  325/60/18 (33.4”x12.8”) on 18x10 w -24 offset.  Yes I had to trim, metal and plastic, but I have no rub.  Truck is aligned, no stress on balljoints or cv’s. Tires sit about 1.5” out from flare, which is not too obtrusive and give it a good stance.
I’ll upgrade the UCA’s next.  But more wanted to see if the above could be done!  Appreciate the thread and posts (and arguments too)!
How do you figure? You added a .5" spacer,  max bilstein lift, a -24 offset wheel and a 325 heavy tire. Yeah, you have added some stress from stock... Have you said a prayer for your steering rack and wheel bearings?
Tyler
Tyler
True Tyler, any amount of lift will give stress. I was talking about the angle on the cv and balljoints that often you will see when people run those leveling kits (2-3”).  From this thread it’s been proven the strut lift mitigates that problem, and in my case the 0.5” doesn’t exacerbate it.
Does a 7” lift to fit 35’s come with a steering rack and wheel bearings?
There is another believer out there  :thumbs:
Ok, so what is your total count at? I know you track it to use it as a sales pitch at work...
Tyler
Tyler
Maybe I work for Bilstein......  :cool:
How do you like the ridge grapplers? I was looking at them for mine.
Just drove down to the Gulf of Mexico from Dallas on them.  Very low road noise, nice balance, so far can’t complain.  Have done very well in sand.  I did not get a lot of miles out of the stock Goodyears that came in the truck (about 20k before they started cupping).  I’ve run (on Jeeps) Goodyear MTRs, Yokohama MTs, Mickey Thompson MTs, Interco SS and Nitto Trail Grapplers in the past.  So far these, as popular as they are, seem to have the best of both worlds (road and play), and they are lower cost from Toyos which seem to be the only ones with a similar RT style.  If they get 45k miles I’ll be happy!
which struts do you guys recommend? 5100's or 6112's? I drive 85% highway/10% city and 5% off-road if that. I commute 80 miles a day and I'm looking for something that'll be comfortable on the freeway, hold up better than the ranchos, and be decent on washboard roads. Don't know if the 6112's are worth it for me with such little off-road?
Hey guys - long time lurker - first time poster.
Original owner 2017 Silverado Z51 that has a RC Aluminum leveling kit. 2" part number 1308 on a set of 295/55/20 tires.
I am thinking about doing the Bilstein 5100 shocks and struts. I don't dislike the Z51 setup, but I am sure it can be improved upon. Truck has 36K on it.
I like how the truck currently sits and don't want to mess with this.
Far from an expert on shocks and suspensions so my question is - can I leave my 2" RC leveling blocks and just install the 5100's at "stock" height and they should be the same as my current set up?
Is that correct / is it possible?
Obligatory pic of my truck. sorry not the best angles but all I had on hand.
Edited by DaddyHasABigTruck
That’s exactly what I did on mine.  Truck rides great.
I went with the 6112’s because it is the strut/spring combo the truck should have from the factory, just replacing stock strut and keeping factory springs will only change the ride 50%. Might as well do it once and be done! I drive the same style as you and am so glad I waited for the 6112’s, installed myself as it is a piece of cake!
let me know if you have any questions or want more info?
I removed my spacers when I installed the 6112’s, better geometry taking them out when running factory control arms. Put the 6112’s or 5100’s on the top ring and your at the same height up front with a better ride!
On 6/24/2019 at 2:40 PM, Whitty21 said:
Hey Guys,
Did some digging but couldnt come up with much.
I assume everything is the same for the 2019 limited editions? Anyone know off hand which control arms came on this model? Just picked up my 2019 sierra limeted z71 a month ago and debating the 5100's
As far as I know, the Limited is essentially the same as the 2018s.  Every part number I’ve compared on my Limited matches the part numbers on the 2018.   I think all the Limiteds were all configured with the stamped steel UCAs.  Mine did I know for sure.  You are correct, very little info out there on these.  Someone please correct me if I’m wrong.
Hey everyone.
pulled the trigger on 5100s for front and rear. My current set up is 275/55/20s with an RC 1.5 level. Hoping to Install on highest setting with level removed and I was wondering if I should be on?
Edited by acc412
    • I was using recirc/max air. Especially if it really hot i start out by lowering the front windows a little with regular ac the go to recirculation after a few and rolling windows up. And it does not have the newest refrigerant. It has per the info under the hood r134. Not the new r1234yf.
    • tldr; Shade tree mechanic stumped by variable displacement AC compressor.   Not Silverado related, but for my 2000 Camaro SS. I've never really used the AC since acquiring the car a good handful of years ago. I plan to take it on a trip this summer so I wanted to make sure the AC was in good shape. On an 73 degree day in the shop with the car idling I set the AC on "Max", temp set to cold, and fan on hi. The compressor turned on and air turned nice and cold.   I let it run for several minutes but noticed the compressor never cycled off. The engine was up to temperature enough that it began cycling the cooling fans on high. I had a set of manifold gauges hooked up and it was consistently at about 25 psi on the low side and between 200 and 225 psi (warm engine) on the high side. Per temperature charts, the low side is low (should be 30-35) and the high side is a little high (up to 170 per chart). I read the low pressure as potentially being under-charged underscored by a continually running compressor This was also underscored by temp readings of mid-20 degrees at the vents. Not just cold, freezing cold. Switching off the AC but leaving the HVAC fan on high produced a deluge of condensation underneath the vehicle. I was getting ice buildup on the evap core most likely.   The low reading (25psi) concerned me that the compressor wasn't switching off so I swapped out the pressure switch. No change in behavior, still ran constantly.   The AC clutch works fine as it engages/disengages with the HVAC switch on command. The compressor relay is good as I swapped it with two different known good relays just to be sure. Having eliminated that, and the pressure switch, I added refrigerant, thinking the constant run and low "low" pressure were signs of a slight undercharge. Makes sense, the car is 26 years old and it doesn't appear the AC system has ever been touched.   Adding some R134a didn't meaningfully change the low side pressure. And that's when a lightbulb flashed upstairs. While I consider the car "old", it's possibly "new" enough to have a variable displacement compressor. Did some reading and sure enough. Dangit. I don't work on these for this reason.   Adding refrigerant means the compressor will just compensate and won't really change pressures until it's severely overcharged or undercharged. But at least I wasn't getting ice/frost anymore, but instead high 30 degree temps out of the vents. That's more normal, but with variable displacement now I have no idea where my charge level is at. It's probably overcharged now. The high side even with the engine radiating serious heat was never really over about 225.   The static pressure at room temperature is dead on, before and after the charge. Both high/low equalize after some rest.   I'm thinking I'll need to take it to a shop. I want the proper charge level so I'm not working the compressor too hard. The only way to get an accurate charge is to evacuate and then re-charge with the exact amount specified for the system -- at least that's what I'm reading.   Anyone here with modern automotive AC knowledge?
    • Mine is in the shop for the AC now. While it did get cold after a bit, it would take a while to even start to cool the air at all. Turns out the compressor was bad and cycling.
    • I call B.S. when I first moved to Texas my first house would only cool to 80 with the Texas heat. The AC tech said it was normal at 100 degrees outside. I remodeled the house put in a new AC. I could hang meat. My cars may need recirculating to start. Once moving it switches to regular AC and I could hang meat. Living in Texas no one would put up with only 20 degrees difference.
    • AC in home or auto only cool down 15-25 degrees from outside temp, but what will help is to put the ac in recirc mode this will recirc the Inside cabin air rather then trying to cool down the outside hot air, I always have mine in recirc mode.
