Swap Silverado Controls for Sierra
So my truck is Victory Red. And i have a red addiction so obviously all the Silverado "Blue" drives me crazy.
Curious if anyone has swapped out the blue controls for red controls? I am even thinking the cluster if it can be done.
I have found the, hvac, lights and 4x4 controls parts but not sure if the cluster could be done.
I would be ok with just swapping the panel but I don't think its possible and I haven't found anyone doing custom ones.
Also I have z71 and my cluster has z71 on it an I am not sure of the Sierra's have that on their cluster.
Thoughts?
I want to go the other way. Have a blue GMC and would like to go to blue lighting. Too bad we are so far apart (and in different countries) but I am interested in how hard this is to do.
most of the parts are modular and easily swapped around. the gauge cluster would be the hard part.
Gauge cluster would require programming from one of the members here (GTP something, can't recall offhand) as GM won't do this.
I have a 1500 Silverado WT2 victory red and have the same problem. I'm not so concerned about my cluster since the WT2 screen isn't in color, but I've been trying to find Climate controls along with other stuff and it's harder than I thought. I can get the light switch (gmc) for $30.00 oem which I think should work and the climate control for a little over $100 I think. where I run into an issue is the radio controls. The whole thing is integrated into the mylink. So I'm thinking I should just be able to buy the intellilink screen and plug into my mylink computer and walah red buttons on a mylink... The downside... I have a 4" io4 screen and I don't know where on this planet to find one used or new from GM.
yeah the radio controls are the priciest outside of the cluster.
http://www.gmpartsdirect.com/gmc/sierra-1500/23168172/2014-year/sle-trim/5-3l-v8-flex-engine/body-cat/sound-system-scat/?part_name=radio-control
holy crap on the radio control, I think I would try disassembling it an solder in red leds
I've heard they are really small and quite difficult to solder. But for the difference of $1,200 I think I may try it when I get the chance
Or $500 in the case of the one you found
I was debating looking in a junkyard and seeing if I could pull some controls out of a wrecked Sierra
Keep in mind some of these control units are VIN coded based on trim levels, so swapping switches or modules may not work, example HVAC controls. Its looking like a LED or light swap is needed, possible its a filter or plastic color cap and maybe removable, someone would need to pull apart a used unit to test with.
Did you read somewhere the HVAC controls are vin coded? The parts look readily available from gmpartsdirect.com
No offense to anyone but, dang you guys are getting down to the finer points here for that kinda $$. I did have a GMC and the red is so much better to look at compared to the blue.
I'm more of a blue person myself. That's probably the only thing about my GMC that I do not like. If I could swap it all to the Chevy blue color I would. :)
Sounds like you guys need to start sending parts back and forth to each other. Much cheaper than buying new parts.
  • 4 years later...
Has anyone gotten anywhere with this thread? I'm interested in switching to red on my 18 2500
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
