i have a 2015 rally2, 4"bds lift, running nitto g2 285/50/22 with stock rims(about 25,000 miles now), not many choices in this tire size(wish bfg made them), mounted a 325 but looked like it would rub(on stock rims) overall g2 in wet weather is a decent tire!
I have finally bit the bullet and got the 285/55/22 Nitto G2's. First of all they look amazing on the factory 22's. They ride nice and are really very quite (slighlty louder than stock but only barely) I have run lots of mud tires though so these seem super quite lol. Now regarding fit These really do fit pretty well considering the size of the tire. The biggest issue I have is with GM molded mudflaps I have on my truck I have had to trim them down on the inside corner. The felt liner is no issue at all and I pinned back with a zip tie to the closest body mount and you cant even tell. I am still having rubbing on parts of the mudflap in reverse and will probably trim more to eliminate the issue.
Those look great man! Definitely add some meat to the 22's. I love the look of the bigger rims on these trucks but hate when they loose too much of tire, this seems like a good balance.
Thanks man. Agree completely the small sidewall was always disappointing but loved the larger rims on the new style truck. The picture doesn't even do them justice in person they look awesome with the meatier sidewall. Certainly fill up the wheel wells
Here is my 2017 Sierra Denali with leveling on 285/55/22 G's. No trimming. Rubs a bit when backing up my driveway. I might do a bit of trimming. I haven't decided yet. Love the look though.
Edited by D-dubs
Which leveling kit are you running? Wanting to add 2.5/1 leveling kit to add the same Nitto G2 tires you have. Really like the Rough Country 2.5/1 kit but just spoke with them and they don't yet have a kit to market for the AVV stamped steel HD control arms on my 2017 Sierra Denali.
ProRYDE 2.5 leveling kit
Dang! I'm running that same tire (34.4" tall) on a 4" Fabtech. Where does yours rub? Driver or pass side ?
Thanks! Do they have a relocation bracket for the magneride suspension? I couldn't ascertain from their website, or did you need to do a dealer relearn?
Can I ask you a couple of questions about the Fabtech 4":
Are you using the budget lift or the uniball?
What size tires are you running?
Do you have a 4wd/AWD Denali?
Are you running OEM wheels?
Do you have any rubbing?
Thanks!!
Thanks!!
Sure, let me know what else you'd like to know. I'm running the uniball kit with the heavy duty ball joints
I'm running a Terra Grappler G2 in a 285/55/22, which measures out to 34.4", only .2" smaller than a true 35". It's roughly .5" thinner. I chose to run a 1" spacer and I am really happy with the look. You will read people go back and forth with their opinion of/on spacers. I did my research and I am happy with my decision. I may at some point get wheels but I wanted to keep the OEM look, just a little more aggressive.
My Denali is a 2017 1500, crew cab, short bed,
4WD.
I'm running the factory 22" that comes with the Denali ultimate package.
I have a 1-1.5" section of my fender liner where I rub on the driver side when I turn left in reverse. I haven't trimmed anything else or removed the lower bumper valance.
I was really surprised when the other member was running this tire on a level kit. That's a massive tire on just a level. It has to rub ..The kit I have is designed for 33s, and it seems like it barely fits the tires I run... I had a 2.5 level before this and there's no way they would have fit.
I'd highly recommend the Fabtech kit. It integrated nicely with Magnaride and I truly think the majority of the additional roughness is from the 10ply tires. I'd say it rides like a 2500 HD.
Hope this helps!
Yes, they said that they had a relocation bracket that went on the magneride.
4WD.
Hope this helps!
Helps a ton, thanks!
I ran 1.5inch wheel spacers on my last truck (2008 Toyota Tundra) for 5 years and 50000 miles with never a problem! Did you add spacer for the wider look or to minimize rubbing? Front and back wheels alike?
What 2.5 leveling kit were you running before switching to the 4 inch Fabtech lift? Did you like it and how was the ride?
I was also surprised at the tire size on a 2.5 inch leveling kit, but the same wheel/tire combo is being reported in other threads on this forum by other members, also only reporting minimal rubbing at full lock in reverse. Seems like an inexpensive way to improve the look and maintain the ride (except for the tire differences).
Lastly do you have truck photos of the 2.5 level or the current 4 inch lift?
Thanks again for the help as I work out the best path to toughen up the stance of this truck a little!
Cheers
Cheers
I added the spacer for the look mostly. It's the same front and rear and it looks pretty solid. I ran a SuspensionMaxx 2.5" level. I loved it and the bracket for the relocation of the level sensor was good. It was actually accidentally transferred to the Fabtech control arms and it ended up making my whole lift ride better because it put the sensor at a better angle. Here's the truck with the level.
The ride was pretty much same as stock. The only time I could feel a difference was at 75+mph and I think the aerodynamic change was the biggest difference.
I would highly recommend a true lift for such a size tire. Yes, it could technically fit on just a level, but it really doesn't make a lot of sense to limit the movement of the suspension that way. But I built this truck to be able to drive through a ditch if I feel like it... haha you know what I mean though.
Here's the truck with the Fabtech 4". I'd highly recommend this set up. I'll take pics of the upper ball joint if you want. It's solid.
0d1397f4b8cd7e60a47b13f54f02d9b9.jpgc6172030c12927cb05a027c201fc1494.jpg70e43d415075285f94124f57dd6a4fba.jpg
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
    • Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
    • Knowing the life of your brakes is a highly important status to keep track of. If you suspect your brake sensors need attention, please fill out our support form with additional details on your experience. When did you last take it in for inspection? Our team will follow up with next steps as soon as next available. Please include your username and GM Trucks Forum in the form as well. Support Form: https://s.chevy.com/support-request
    • I just purchased a 2004 Tahoe with 148,******. I used to have a 2006 Suburban that had the push button Auto 4X, 2Hi, 4Hi and 4Lo. When checking out this truck I noticed it had push button but didn’t focus on it. After the purchase when driving home, this is when I noticed it was different and after a little research found out it has the AWD stabilitrak system. I don’t live in an area that requires AWD. I bought the truck to start a new adventure in life with off roading, now that the kids are all grown up. I purchased the truck knowing it didn’t have the G80 rearend but plan on re-gearing to drive on 33s or 35s and upgrade with a rear locker and still be able to tow when needed. Blah Blah Blah Anyway I know am thinking about converting the stabilitrak  to Z71. I know I will have to replace the transfer case. So now the information gathering stage is happening to see if it is worth it. Is the front AWD stabilitrak differential different when compared to a non-AWD front diff? Will I need a completely different front differential or can it be converted? What else should I be considering? I did see something in a video for GMT900 platform with removing the ABS fuse that disables the stabilitrak and turns the truck into a 2 wheel drive. Would that work in the GMT800 platform?
