On ‎8‎/‎29‎/‎2019 at 7:21 AM, Truston Gunter said:
I have a 2015 LTZ Z71 with 41,100 miles and seems like I am leaking refrigerant from the condenser. Really sad that this truck is having these kinda issues and of course, no help from the dealership. Warranty expired May of 201920190827_181648.thumb.jpg.05d2435b81b21ff5d766bb8cf9fd7665.jpg
Sorry to confirm your suspicion, but yes yours is leaking.
If mechanically inclined you can replace yourself for under $200 including new refrigerant.
Thanks for the confirmation Dan!!! I went ahead and replaced it myself! Vacuum held for about 45min so I dont think there are any other leaks, I guess time will tell but in the mean time I got COLD AIR!!!!!!!
Good news indeed Truston   :thumbs:
Now we all have to get in line for the Brake Software Recall :nonod:
Took my truck in today for an oil change and tire rotation. They did the brake update in about 10 mins.
I had the brake update done on Friday, problem is worse, so now I have to wait for the recall to get brake booster replaced
Who else has had the "update" performed?
Did it make your truck worse or better?
wait for the recall to get the brake booster replaced? You mean the Vacuum Pump?
What year and mileage is your truck?
81k miles on my 2016 and the AC finally gave up today, it's been performing poorly for the last week or so.. Have an appt. with the Chevy dealer on Saturday for a diagnostic... Watched a youtube vid and it doesn't look terribly tough to DIY it but, what about the vacuum portion mentioned? What does that tool cost?
Just see if your clutch is locked while the ac is on. If not, there is no freon in the system. Look at the usual spot where the condenser leaks and see if there is any wet dust or dirt.  Price is about $200 for the whole job. I bought new o rings just for security. Which added about $40. Not needed. Auto Zone rents the pump and gauges for free.  SAVE THE DIAG FEE AT THE DEALER.
Edited by RACERX7775
Thanks for the info... Only a few hot days left here it looks like so I may just DIY it and borrow the tools like you suggested at Autozone..
22 hours ago, RACERX7775 said:
I say go for it. It's pretty easy.
Yeah the videos sure make it look that way.. I'm slammed at work right now and have a lot going on at home so if I can get GM to pick up some of the tab it might be worth it for me to just pay the dealer to do it but, I ain't gonna pay $1300 that's for sure, I'll take a PTO day from work before I do that but, for $500ish I'd be happy to pay someone else to do it..
Edited by Imcrazy
Just spent 1400$ on a new complete system, compressor, condenser lines rings etc. at an independent dealer with 1 year warranty. The dealership wanted 900 for just compressor and no warranty.  My truck has 65k.
  • 5 weeks later...
Mine gave up at 63,000. I ordered a new condenser off Rock Auto for $80. The hardest part about replacing the condenser is getting at all the bolts that hold the bracket at the top of rad and condenser. The rest was pretty damn easy. Borrowed gauges, vacuum pump, a jug of r134a from a guy I work with and charged the system back up. Running good now. No way would I oay ANYONE $1400 for this repair.
Add another to the list. 2016 Sierra just shy of 43,000 miles. Already ordered condenser. Now debating to borrow (Auto Zone) vacuum or pay a local shop. Local shop quoted $950 for repair and ~$225 to vacuum and recharge.
    TopBo
    TopBo
  • Who's Online   6 Members, 0 Anonymous, 843 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
