On ‎8‎/‎29‎/‎2019 at 7:21 AM, Truston Gunter said:
I have a 2015 LTZ Z71 with 41,100 miles and seems like I am leaking refrigerant from the condenser. Really sad that this truck is having these kinda issues and of course, no help from the dealership. Warranty expired May of 201920190827_181648.thumb.jpg.05d2435b81b21ff5d766bb8cf9fd7665.jpg
Sorry to confirm your suspicion, but yes yours is leaking.
If mechanically inclined you can replace yourself for under $200 including new refrigerant.
Thanks for the confirmation Dan!!! I went ahead and replaced it myself! Vacuum held for about 45min so I dont think there are any other leaks, I guess time will tell but in the mean time I got COLD AIR!!!!!!!
Good news indeed Truston   :thumbs:
Now we all have to get in line for the Brake Software Recall :nonod:
Took my truck in today for an oil change and tire rotation. They did the brake update in about 10 mins.
I had the brake update done on Friday, problem is worse, so now I have to wait for the recall to get brake booster replaced
Who else has had the "update" performed?
Did it make your truck worse or better?
wait for the recall to get the brake booster replaced? You mean the Vacuum Pump?
What year and mileage is your truck?
81k miles on my 2016 and the AC finally gave up today, it's been performing poorly for the last week or so.. Have an appt. with the Chevy dealer on Saturday for a diagnostic... Watched a youtube vid and it doesn't look terribly tough to DIY it but, what about the vacuum portion mentioned? What does that tool cost?
Just see if your clutch is locked while the ac is on. If not, there is no freon in the system. Look at the usual spot where the condenser leaks and see if there is any wet dust or dirt.  Price is about $200 for the whole job. I bought new o rings just for security. Which added about $40. Not needed. Auto Zone rents the pump and gauges for free.  SAVE THE DIAG FEE AT THE DEALER.
Edited by RACERX7775
Thanks for the info... Only a few hot days left here it looks like so I may just DIY it and borrow the tools like you suggested at Autozone..
22 hours ago, RACERX7775 said:
I say go for it. It's pretty easy.
Yeah the videos sure make it look that way.. I'm slammed at work right now and have a lot going on at home so if I can get GM to pick up some of the tab it might be worth it for me to just pay the dealer to do it but, I ain't gonna pay $1300 that's for sure, I'll take a PTO day from work before I do that but, for $500ish I'd be happy to pay someone else to do it..
Edited by Imcrazy
Just spent 1400$ on a new complete system, compressor, condenser lines rings etc. at an independent dealer with 1 year warranty. The dealership wanted 900 for just compressor and no warranty.  My truck has 65k.
  • 5 weeks later...
Mine gave up at 63,000. I ordered a new condenser off Rock Auto for $80. The hardest part about replacing the condenser is getting at all the bolts that hold the bracket at the top of rad and condenser. The rest was pretty damn easy. Borrowed gauges, vacuum pump, a jug of r134a from a guy I work with and charged the system back up. Running good now. No way would I oay ANYONE $1400 for this repair.
Add another to the list. 2016 Sierra just shy of 43,000 miles. Already ordered condenser. Now debating to borrow (Auto Zone) vacuum or pay a local shop. Local shop quoted $950 for repair and ~$225 to vacuum and recharge.
    • As the title suggests, I have an unused General Motors authorization code for a set of bed perimeter lighting lamps that I bought. My truck was built with the option for perimeter lighting, and they worked without programming… So now I just have this code. What is it good for now? Can anyone here use it?
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
