What's your oil consumption?
Who said, I am complaining? I am just not going to do 7,500k OCI? And why would I pay dealer down the street 89.99 which they will only give me Semi-synthetic and a p6F4 AC delco Ecore garbage filter not to mention the 2-3hrs out of my day? I have a CATCH CAN YO? So it's actually going to be OK for somebody like me who is pounding the miles. And the particulate matter is Handled by the Decent Synthetic filter......Real genius stuff here, boss! I will extended it even longer probably to 12K when I get the UOA. So yeah, only real problem is the cabin air filter and engine air filter going on here shocking as it sucks in more dirt in 3-4 months than yours in 1+ year.
  • Replies 117
Ok you're clearly an idiot, as evidenced by your inability to form coherent sentences.
1) you complained, when you mentioned, three times, the price of your oil and filter.
2) I pointed out that the dealer charged me under $50 for 8 quarts of oil and a filter, so no, there's no reason to pay the dealer $86, but lots of reason to pay them half. That's why I said you could pay them half, as in $45. That's what "almost half" means. That's how math works.
3) filters aren't synthetic, filters are filters and filter according to their design, in microns. There is a LOT that gets by filters (if filters were 100%, oil wouldn't change color with usage, nor would oil flow through said filter). It is the oil that is synthetic, which protects it from thermal breakdown and shearing, but does not protect it from contaminants. Filters still have the same lifespan as they've always had, actually less: as filters trap smaller and smaller particles, their longevity decreases, because they clog sooner. Luckily for the engine, filters have bypasses in them, so that the oil flow does not shut off and starve the engine of oil. Unluckily for engines, this means that unfiltered oil is now flowing through the engine, further increasing wear. So congratulations in probably running unfiltered oil in your engine under "extreme" conditions.
4) congrats on your catch can YO! That and a $1.25 will get you a cup of coffee. Catch cans are NOT 100%, so you will get aerosolized oil and contaminants in through the intake, especially as oil wears and becomes further saturated with contaminants. As the ratio of solute:solvent increases and said solvent then heat-evaporates, said contaminants are left behind, coking up the intake plumbing.
But thanks for your inputs, really. There's no better way to find out who on the internet is a good source of information and who isn't than by reading the nonsense they try and write.
Filters can have synthetic media, and allow longer oil changes and provide better filtration.
I'm still amazed at $85 for oil and filters...I picked up 8 quarts and an oil filter for $45 at the dealer, so I highly doubt they'd charge $40 for an air filter... if dust is such a problem that the air filter needs changing at 10k miles, then that dust is also in the oil too, which would require MORE frequent oil changes. Few free to check the owner's manual or literally a hundred years on the effect of harsh conditions on engine oil for clarification.
As per oil consumption, check that PCV system...clogged filters, broken diaphragms, clogged lines can and do lead to engines consuming oil through the intake system, rather than past the rings or valve guides. Though Chevies have historically blown oil past the valve guides...
then that dust is also in the oil too, which would require MORE frequent oil changes! You go bud! I will stick to being the idiot that you proclaim and change the Fram 8755 at every 10K...maybe 12K if UOA looks like it will be good until then....P.S I am really a Ford guy by the way
Look, your kinda crazy......I have been doing 10K oil changes since the 90's "ok" What I have not done them on is "GDI" I think I will be "OK" at 10K hopefully 12K and unfortunately I have to change the air filter at that interval? The only person upset over this apparently is you?
So glad you could interject with all your hyperbole. I am much more informed now and will.......find out who on the internet is a good source of information and who isn't than by reading their nonsense.
I was going through a quart of oil every 2000km. I had it documented and every time I went in they took the truck and checked it and told me they didn't top any up yet I caught them doing it and they lied to me. Obviously GM nose there consuming oil or they wouldn't have such a high allowable consumption spec
Sorry I didn't elaborate more on synthetic filters. Filtration is dependent upon porosity not medium. While different mediums may physically break down slower, clogging rate increases as porosity decreases. Or, said another way, permeability decreases as porosity decreases. So yes, while a synthetic filter should last longer and thereby have a longer lifetime of filtration, the severe use aspect would simply clog the filter sooner and require oil bypass, rendering the fact that the media has deteriorated to be moot.
Synthetic media have a finer filtration to begin with (versus cellulose)...the two reasons they came up with glass media was better filtration and longer life without sacrificing flow rate.
I've researched this topic way more than I care to remember...ran more types of bypass filters than most could name.
Further, I have no dog in this fight. I was originally responding to the statement that filters aren't synthetic.
Have a nice day.
You're going to an extended OCI WITH a Fram filter? Oh sweet Jesus.
Out of curiosity what does being a Ford Guy have to do with anything about oil?
I LIKE POPCORN. Who cares?
Honestly, is it affecting your mental health or pocketbook by someone else sharing their rationalization for the way they perform their maintenance? No? Then why are y'all taking it personally? Instead of attacking, perhaps a "thanks for sharing your opinion, here's mine" would have sufficed?
This ^^
I don't try to convince anyone on any forum I belong to that they are wrong, waste of time. I post my opinion or my way of doing things to give a different perspective. If you gain some knowledge from my ramblings great. I don't care how you put your pants on. :happysad:
39000 miles.. no oil consumption.
Forums are to aid others in maintaining vehicles, so when someone offers advice that is akin to routing their intake plumbing to a bag of sand, THAT does no body any good. There is a difference between opinion and asinine advice.
Hey guys, if you add water to your oil, it'll help your engine run cooler, which means more power.
    • Not sure about DFM tech but i know there's a stop/start deactivation button.
    • I could be interested if they axed cylinder deactivation and at least have a button for stop start. I’m sure the HP numbers will be higher. I would want a longer warranty to help build confidence. I’m a less is more guy as I get older. A V-8 work truck model would be my choice. I know a few outfitters for custom additions I prefer.
    • It's official. GMC pulled the covers off the next-gen 2027 Sierra 1500, and we got the first official look. Full breakdown here: https://www.gm-trucks.com/next-gen-2027-gmc-sierra-1500-v8-trim-changes/   The quick hits: SLE and SLT are dead. The new core retail trim is just called "Elevation". Two new V8s, a 5.7L and a 6.6L built with high-performance Corvette architecture roots. No horsepower or torque numbers yet. The 2.7 TurboMax finally ditches the old gearbox and gets the 10-speed automatic. AT4X moves to larger standard 35-inch tires with front and rear e-lockers, Multimatic DSSV dampers, and heavy-duty Jounce Control Dampers. Over 60 inches of combined display on Denali Ultimate and AT4X, complete with a motorized articulating center screen and an adaptive passenger screen. Seven simplified trims across the entire model line to clean up ordering confusion.   So let's get into it: New 5.7L and 6.6L gas V8s with custom active exhaust tuning and a Corvette connection. Is this the exact engine lineup half-ton traditionalists have been begging for? Purging the iconic SLE and SLT names after all these years to lean entirely on Elevation as the high-volume core. Bold move, or a mistake? That motorized articulating 16.3-inch screen that slides up to reveal a hidden dashboard vault. Awesome mechanical theater, or does it make you nervous about long-term durability? Physically lowering the headlamps in the front fascia to improve road courtesy and stop blinding oncoming traffic. Smart real-world engineering, or does it hurt the truck's aggressive stance? What trim are you putting your name down for on day one? Drop your first impressions below.
    • My overnight hospital stay turned into five.  I developed a post operative fever and an erratic  heart rate.  A blood clot in the lungs was the culprit.  This is apparently a common post surgical complication and easily remedied.   I was the youngest in a four bed ward and a Doctor with a Geriatric specialization was in charge of my care.  All of the nurses were good and some were outstanding at dealing with old people.  It was very evident that my age triggered a different level of care!  My advice to any senior going for a hospital stay is to have a trusted family member advocate visible.  If not, you will still be well cared for, but you may discover that your voice  isn't as strong as it once was!
    • $4.25 85 oct. in town, down 50 cents.
