2 hours ago, RACERX7775 said:
If you have the truck running and the radio on, and on a preset radio station highlighted at the bottom of the screen, when you turn the truck off, but dont open the door, does the preset stay highlighted, or does it go dark, then highlighted after a few seconds.
I got you.  Bose '15 here and I did the upgrade from WAMS.  Under the conditions you've stated, the preset remains highlighted and the screen stays normal playing the music until I open the door.
I'd suspect your radio module, but perhaps WAMS or magpie can chime in if they've seen this before.
808, thanks. Its like its ignition related. I also have the NavTV module in my truck which extracts audio and sends it back via optical cable to my jl audio amps.  I had a problem with the truck theftlocking the hmi several times.  It works perfectly except for that. To get audio back I actually unplug the gray connector on the radio module and plug it back in. Or, believe it or not, If I select onstar, then go back to radio, the audio comes back on. I also thought that the welcome screens werent coming on all the time. They only come on if the truck sits for a while, I open and CLOSE the drivers door but dont put the key in. I think.... I swapped back my factory radio module, and it still does it. I hate to even think its hmi programming issues.  It works PERFECTLY with my factory 2.0 modules.
And they BOTH have tried VERY hard to help me get this figured out. I actually thought it was a bad HMI because it did it with a different 2.5 HMI and the this radio. But was fine with my 2.0 hmi and this radio. So makes me say the radio is ok.  My truck just doesnt like the 2.5 hmi setup.
You also have a 15.5 hardware wise :)
In the vast amount of these we've done (going back to late 2012) I cant remember any vehicle giving anyone such a hard time as his and its done some REALLY weird stuff. It almost seems to be a power moding issue but its hard to pin down, couple that with aftermarket equipment, a salvage radio unit etc its really hard to tell :(
EDIT: My first thought now knowing about the NavTV (news to me!) would be to remove that and see if the issue is resolved since it hijacks both busses to operate and generally thats a bad idea but aftermarket companies love to do it! Its also possible (but admittedly a long shot) that a bus revision mismatch from the cluster + NavTV (depending on which frames it uses for which operation) could be contributing.
Edited by GTPprix
I was typing up a response to racer saying this exact thing when your post notification showed up. I'd try and get the setup back to "stock" without the navtv and go from there.  If it turns out the navtv is the culprit, I'd tap the amp in the back seat to get the audio signal for your amp using an audiocontrol unit.
Great minds :) I just want to help him get it running its really an anomaly i've never seen an HMI learn HALF of a VIN before... like ever... and thats over thousands of units lol
Whew.... yeah. The good part is i know how to get audio back very easily. The bad part is how to fix it. I removed the navtv out of the system to see if that cured it. But then I have no audio anyway. But with it completely removed, I can watch the radio preset go gray when i shut the ignition off, then a couple seconds later its highlighted red again, but audio is gone. I have alot of stuff in this truck. And it appears that the 2.5 module upgrade just doesnt like the stuff.
Another thought, power moding is BCM controlled and 2014's have a TON of BCM updates (typical for a first year vehicle) maybe try getting the BCM updated to see? Worst case we can toss another radio at it if you want to try that.
Chris, And I thank you so much for the help with this and not throwing your hands up at me.
No problem man!! We will figure it out one way or another :)
Im also working with the engineers  at NavTV too. Its just so weird. I have still never heard the startup and shutdown sounds. With the 2.0 hmi and new radio, its perfect. 2.0 hmi and original radio, its perfect. 2.5 module and either radio, its issues.
A side note is that with android audo, all I have to do is  say ok google, and it works. I dont have to touch anything. The steering wheel voice controls work perfect as original 2014.
Yeah something isn’t waking up on time and shutting down early. Sure sounds like the NavTV but sadly impossible to tell remotely. There were quite a few bus changes between 14 and 16 so that sadly isn’t surprising.
And its mostly just when ignition is turned off. Thats why i asked what the presets do when the truck shuts off. With the navtv disconnected, the issue still happens with the presets. And I have confirmed that there is no audio coming out of the radio when this happens.
What other aftermarket wiring modifications were made for the stereo? I guess we’d need to know how the amps are wired in etc... so many variables :(
EDIT: DUH. The Amps are probably wired for key on power... the Welcome/Shutdown sounds both occur when the ignition is off... no wonder you've never heard them.  (or they are tied to power moding etc) just spitballing here but it would certainly make sense.
(oh and the DUH was for me... like why didn't I think of this sooner)
Also we are dragging this thread off track, might be best to take this to email.
Edited by GTPprix
Why did I not catch that in the last post? LOL
Amps are only tied in with the optical cable from the navtv unit. And then spliced out to my speakers. BOSE amp still hooked up but not connected to speakers. The blueray player in the center console video goes to the sceeen via a camera module from MVI. Audio goes from rca of the blueray to the headphone jack at the usb in the center console when switched to AUX on thw radio. That also gives me cameras at all sides, front and rear.
There is a ton of stuff in my truck. And now its only the audio that has the issue when the 2.5 module is in. I have removed the 2.5 module and reinstalled the 2.0 module.... All works perfect.
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • As a matter of amusement I’ll leave this conversation with this. Do you beat the government average fuel estimate? Statistics are a guide to me. Not a rule. Someone once said I have to have the last word. If true and possible may be. I’ll blame that on working in a family business.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
