Hello everyone.  I am kinda new to the party.  I just got a 2015 GMC Sierra 1500 Denali with 8" screen and no Nav.  I have been going through this forum to try and find out exactly everything I need.  So far I am 99.9% sure I need a 2.5 HMI pre-programmed to my VIN as well as a USB adapter to replace the USB with SD Card I currently have.  I also see where some people needed a new radio module but I am not sure if I need that or not.
**Edit** I should mention that I am wanting this upgrade specifically for Apple CarPlay
I had gone through this process with my 2013 Ford Fusion for about $400 late last year, but with that one I was able to do all the programming myself with a bluetooth OBDII adapter.  I feel that the GMC will require less work on my end to actually get it up and running but I am having a hard time nailing down who/where to get the parts from and exactly what I need.  I was hoping to avoid the $999 and up kits.
Edited by fritzscorner
I just did this upgrade on my 2015 Sierra 2500HD with 8" screen and no Nav (the IO4 accessory option). In order to upgrade it you need  the HMI module (105 from 2016), the faster 2.5 processor, and a new center console USB port. The HMI has to be programmed for your specific vehicle/serial number. The kit was $899 from MVI for the no OEM nav or $1299 if you want the IO6 module to give you GM factory navigation (I didn't need that since CarPlay would give me at least three navigation apps). The install took me about 20 minutes with a trim removal tool, a 7mm socket driver, and a 4mm torx bit. Absolutely plug and play, Fired it up and now the Intellilink system is exactly the same as it was before...rear camera works great, steering wheel controls all the same. The only difference is is that from the Intellilink home screen, when I plug my iPhone into the USB port in the center console box, the "Projection" icon changes to CarPlay.  https://www.gm-navigation.com/shop/2014-2015-carplay-enabled-gmc-factory-system/
Dude im so glad i didnt buy from them. I told them I only wanted to add the ability to mirror my android and he said $1,489.99 plus tax. Thats a crazy price diffence. Only thing different is the screen size 4in.this was a month and a half ago.
48 minutes ago, Snowcamo said:
I don’t know anything about their various products. The CarPlay/Android Auto upgrade for my vehicle was $899 +shipping....arrived in less than a week. Install was a snap. Works perfectly. Absolutely OEM. Even the steering wheel buttons work fine.
Right on dude.
Wanted to share my costs for the project for those that are curious.  I did the cluster and apple carplay/android auto.  Everything working as advertised thus far.  These are rounded but are very close to actual.
2.5 HMI and matching radio module, used - $200 shipped (ebay)
Updated USB ports, new-pulled from console - $40 shipped (ebay)
Denali/F-cluster blue green for a 2016 - $405 shipped (gmoutletparts.com)
2.5 HMI/radio module programming - $100 (WAMS)
Denali cluster programming - $250 (WAMS)
Shipping costs (To/From WAMS) - $120
Total = $1,115 USD
I have a 2014 and would like to do the cluster upgrade also, but do the 14 cluster not have the bigger screen? From what I have read in this thread is I need the same year? Thanks Michael
I believe once you do the AA/CP modules, you'll need the blue green 2016 version, as your HMI will now be 2016 spec.  You'll need to contact WAMS for fitment though to be sure.  My 2015 used the 2016 blue green part number for the denali cluster.  WAMS did the entire thing together in one shot for me.
Also to note, I was able to get AA running wireless using a slave device plugged into the center console, though its not without its shortcomings (it also costs 99 cents for the app lol).  Here is a post from the colorado forums that outlines the process.
Have a 2014 LT Z71 with Bose and NAV. I have unlimited access to dealer programmer and GM TISWeb. What would I need to do to have ACP and AA added to my truck with functional steering wheel controls. From what I have read it looks like I have to replace the HMI, Radio, USB, and the Cluster from 2016 and up. Is this correct? As I have access to TISWeb and Programmer do I need to send it off or can I do it myself? Also the newer USB ports do they not have an option with SD card? I wear my current SD slot out. That being said once you get up into certain dollar amounts is it not better to just replace the radio with aftermarket?
Yea I totally understand.  Definitely not a "cheap" mod.  For those of us where factory appearance and function are king, its a small price to pay for the alternative aftermarket looking deal.  I have an alpine aftermarket screen in my '09 silverado, and it looks just that, aftermarket.
I just, literally JUST installed a Pioneer headunit into my wifes car which is capable of wireless AA/CP (wireless AA does not work on my Galaxy S9+ OOTB, but my wifes iPhone should be ok).  It looks OK and has more features than I do (screen mirror, etc), but I did pay something around $800 for the unit and all additional wiring etc to get the steering wheel controls to work, backup camera on two screens, etc.  Everything but the head unit itself looks factory, but if I had the option of spending an extra $300 to get it 100% factory, would I?  Yup, I would.
So with the HMI and radio module....
What is the programming that needs to be done? It is just programming the module to accept my trucks VIN number?
Thats a very small part of it. For example we make some other small tweaks that fix some small quirks when used in a retrofit situation etc.
100% this. The programming can go far beyond that. For example, modules may need to be re-branded to suit your make and model, radio type, country and various other factors.
Some units (most units) will need to be updated to allow full functionality as well.
It's more than just changing the VIN.
I just received my reprogrammed radio and HMI module from @th3magpi3 and all went well. He even turned it around and sent it back on the same day! Thank you
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
    • I’m definitely interested to hear the end result here.
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
