On 10/24/2018 at 7:18 PM, bcj001 said:
Just got the new tires mounted after leveling... love the ride (the eibach kit makes it ride so much better than the stock rancho's, love the look... very happy... bfg ko2 275/65/20 on stock wheels, zero rubbingabd320a3c66d63904adf44722b609c35.jpg4ec7b4b78a51f7e548837fe325f2937d.jpg
Did you do anything with the rear blocks or just the Eibach kit? Looks great my pro truck kit is going on tomorrow with same tires specs,
Has anyone tried these on the highest setting?
Shop that installed my kit accidentally set it up the first time on the highest settings.... truck wasn't really drivable, bouncing all over the place, and had a heck of a reverse rake....
Nope, stock blocks in the back... currently a little nose high (1/2") I might put 1" over stock blocks in at some point... but doesn't really bother me as is... so might not.. lol
Got a little busy with snow starting the day this went on! But I love it, no adjustments in the front I really want to move the front to the 3” setting and add a 1/2” block in the back but don’t want to change the UCAs. Front is sitting about 1/2” lower just off of eyesight.
Running Cooper Discoverer AT3 XLT  275/65/20. Rubs ever so slightly on UTurns. Just requires a little Austin Powers maneuvering!
Very nice write up! Here’s a few questions I have; how difficult is it to adjust the shocks once they're installed as in changing to different settings? Also has anyone towed using this set-up yet?
 I’d love a little lift or atleast level but need some rake for hauling the camper around. If it was easily adjust this set-up would be prefect!
Your not going to want to continuously adjust the front ride height, from what if I’ve read it’s easy but you have to have the strut off the truck and the spring compressed, etc. I currently just have a puck style leveling kit but will be getting this shortly but that’s besides the point. My point is I have a leveling kit and I haul a 30’ travel trailer and don’t have any issues with it. I have sumo springs helpers that replaced the stock bump stops and then my weight distribution hitch takes care of the rest for the most part.
Thanks! Maybe I’m jumping the gun. This truck has not seen travel trailer yet. Ours is only 26ft. Now the Colorado I had previously wasn’t happy at all.
For you guys that installed the eibachs did you replace your UCA’s?
I am going to when I do mine. I've read you have to have the struts off the truck when you replace UCA's so might as well while your that far in
This is the right attitude to have when you replace your struts with lifted ones.  If you have the coin its best to knock it all out at once.
I just ordered this kit and I'm thinking about doing the UCAs as well so I can do it all at once. I'm also ordering a motofab 1" lift block for the rear so I maintain a little rake and should pair perfect with these rear shocks. For UCAs I'm looking at the Rough Country forged control arms for 2.5-3.5" lifts. They seem like a good deal for $250.
I personally don’t like RC, I’ve had several friends that have had real bad luck with their stuff. I know some people on here run them and love them but incase you wanted to go with something else that won’t necessarily break the bank you might look at readylift UCA’s. I found them for 30% off on amazon.
    • The 92-95 SCPI spider injectors are notoriously problematic and hard to source new replacements. I’d pull the intake manifold first to inspect cracked lines and brittle plastic legs before dropping $350 on a rebuild. The 1.5 OBD system only offers limited data, no misfire tracking, which is normal for this 1995 model. Enjoy the project!
    • Yea a fluid change is in order here. Honestly, your transmission didn’t even get hot. During the summer in stop and go traffic I’ve seen my 8l80 get up to 216 and it was still shifting smoothly.
    • I'd change the fluid and start there.   198F is nothing for the 8L90.  They typically operate 180-200F stock.
    • Looking for help!   2019 GMC Sierra 1500 - 5.3l 4x4 8l90 61k miles - truck is in Arizona, was over 110 outside on Monday when this whole situation transpired. Never had any major issues with transmission until this point:   Truck sat outside my construction office for approx 1 hour idling before I realized, ran around the job site wrapping some things up for the day and then left. Went to get food and sat in the drive through for approx 30 minutes idling. As soon as I pull out of the drive through and onto the main road, rear tires lock up and feels like transmission fell out of the truck. Shifted to park, shut the truck off and tried again, same thing happened. Was able to reverse into parking lot (truck slammed into reverse). Let the truck sit turned off for 10 minutes before trying again, but it continued to happen. Towed truck back to my house. Highest the trans temps reached was 198.   Friday, after work I start looking into the situation. Truck sat in my driveway untouched all week. Truck is now driving like normal, transmission doesn’t get over 185 degrees when trying to heat it up. Got up to 60 multiples times with no issues, no issues accelerating, only down shifted hard into first one time at 185 degrees. Does anyone have any insight? Never through a code or a check engine light. Truck has never been used to tow either. No transmission services at this point.
    • Atlas won.   I know better, but I did it anyway. I took a compressed air line with a chuck and rubber tip and jammed it in the open EGR port. The port was clear as far as I could see, and as far as I could poke with a flexible wire, but that doesn't mean it's not clogged.   Compressed air blew back at me along with a cloud of black. Oops. I didn't have the rubber tip seated in there all the way. Jammed it up in there some more and squeezed the chuck. PSI was set to 120. Poof! It blew back at me again. Third time...pfffffttssssssspffffffsssfffffff, face full of carbon, and then, kind of a thud..and the air stopped spraying back at me. It was now exiting the exhaust with a low shhhhhh sound as it flowed through the pipe. Something broke free. I pressurized the port again, and air flowed.   Made my day.   Long story short on this problem, it's fixed. Something was really blocking the EGR passages down low, and compressed air blew it apart. I don't recommend this as who knows what debris was sent where. But it's allowed me to move forward, mentally, and onto the next problems I need to get this little S-Blazer going down the road properly again.
