2 hours ago, jflan23 said:
Got sick of not being able to see while backing up at night (blinding screen and tinted windows)
Great idea! Might have to look into this... I’d be interested in a write up too. Also, CT truck here as well...
Not really that flush but the steps are so big it didn’t matter. They’re whelen Pioneer NANO-6’s however any smaller LED would work.
As for wiring, I tapped the reverse wire from the taillight to trip a relay. Power and ground I grabbed from the back side of the trailer plug. I fused it again since it’s better to be redundant, only needed 5 amps.
I’ll look tonight if the screen gets better, I highly doubt it though. However seeing through the tint using the mirrors should be way better.
Installed a 3 inch by 22 inch curved LED light bar. Cut out the plastic under the license plate. Built a frame with aluminum angle brackets. Still need to wires it up. Plan to tie it into the bright lights. acaea4551fb05a204247d91e02bf7f49.jpgab4609835bf859abfd3f5c05eee38741.jpg90cc45ff9ad1df87a4f991310c5d6319.jpg0737e62e0fade1fa11c8fd844ace3830.jpgd58d32eed6712dec58c90e601202c1a6.jpgf48eb5058795e34ff974057c385a51fb.jpg
17 minutes ago, jimmyboy8301 said:
Did Adams ceramic spray coating and ceramic boost:
8a84da93751517ee85b6546ea017bf61.jpg8c47693213f8da5ac7d540d377e2f59b.jpg2fa45f0385e80c89d7366f6c74da9e9f.jpg
That looks sharp!! I’m contemplating in purchasing one of their polishers and ceramic coating mine again. Did you do any polishing?
No, the truck is brand new and the paint is still in great shape. I gave it a good foam bath and have had paint sealant on it. I used surface prep then applied the spray coating
Installed the Backflip mx 4 tonneau cover. Like it so far. Easy install in about 30 minutes.Screenshot_20200223-151119_Photos.jpg20200223_110458.jpg
Sent from my SM-G975U using Tapatalk
Finally installed a Putco taillight light bar - turns out it's easy with the harness, strongly recommend that for plug n play installation that doesn't soak up a trailer plug (and gives a 4 pin in a pinch).    Also did it without removing the tailgate!   Fully intended to take it off, but then realized it can be done with a helper and some patience.  Thing looks like a light saber under there!
That looks awesome. I have never really liked those that much but that looks great. Do you have a link to the harness?
I used this one,  as recommended by Putco.
https://www.putco.com/529005
Pretty busy day for the old girl today. Picked it up from the dealer, they installed remote start, coded my factory fog lights and installed the gm 2” factory lift. Then I went straight to my tire shop to get my wheels and tires installed. At home I had factory GMC floor liners and the under seat rear storage box to install. I’ll post up some more pics tomorrow. Scheduled out to get my level installed on Friday (dealer wouldn’t do it) and getting the bumpers wrapped matte black. Pretty much done after that for a bit. Wallet needs a break.
Looks great. Which level kit did you pick ?
Thanks! I went with the Rough Country AT4 level. Plan on doing a King upgrade once my warranty is up so I’m just going to run the factory uca for a bit. Im a pavement princess anyway.
Wireless charging for the center console completed.  I hate cables all over the cab, always getting crunched in the console lid etc.  I use the built in wireless pad, but it’s nice for passengers not to have to plug in a cable.  This is a simple DIY project.
first I picked up a wireless charger on Amazon, get the 3 coil kind so you get wider coverage.  Took it apart and removed the guts, used packing tape to keep it all together.  Minimizing plastic between the coils and your phone is key.  I tried using a small single coil one, but it just didn’t have the juice to power the phone thru all the plastic.
take the bottom cover off the console lid, just use a plastic tool, it pops off very easy.  Squeeze the lid release to the top.    Inside you’ll see the grid structure that strengthens the plastic.  I used a paid of nippers (side cutters) to clip off the plastic to make a flatter area for the coils.  I trimmed more than I needed to as I thought I was going to use a larger round charging pad, so just trim as needed.   Then I used packing tape to hold the coils and it’s little circuit board together and stuck it in place.   Tested it to make it charges my phone before closing it up.  Ran the usb cable along the bottom and out the hinge and into the center console.  Works great!
    • No ETA is available for that engine at the moment in the GM system.   I would start at the dealer.  Try and talk to the parts manager or service manager and see if they can start a CX Connect case and get an ETA from GM on when engines may be available.  If they just check Parts Workbench and say "no eta", they aren't trying hard enough.  They need to do a CX Connect and chat with DPAC to find the ETA.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • $4.26 85 oct
