On 5/31/2022 at 3:15 PM, jashaw said:
Xf offroad XF222 wheels -12mm offset
Cooper Discoverer Rugged Trek
275/60R20 (factory size)
Removed lower wheel liner bracket, and pinned wheel liner back in empty space that was filled by the bracket. No rubbing at full turn in either direction.
3/8" spacer to clear calipers
image.thumb.png.ebf27e9633fe92a32f61587d089280b8.pngimage.thumb.png.24f5e12eede763521628dc160bd8e5ec.png
This is so beautiful!!!!
I got a 21 sierra elevation and I blacked out all the chrome badges only thing chrome left are the exhaust cut outs but will be changed soon
Edited by Box God
I had a bit of white vinyl left over from my '21 AT4 so I thought I'd see how the bowties looked in white. This looks better than black IMO. I'm going to have them keep the center caps out of the wheels when I get the tires rotated so I can cover them in white as well.
Finally got a bumper custom made for my truck. Tabbed for 6 Baja designs XL80 lights. Been a little over a year since the stock bumper came off when the fiberglass and suspension was installed.
Got my 2" RC level and 1.5" ProRyde blocks installed. Currently have ~.5" of rake, will see if it changes after the alignment tomorrow. Getting tint done tomorrow and the new tires are also ordered.
20220701_183154.thumb.jpg.33cf74a55a114aa1df607fd093c03db1.jpgPurchased on 6/22/22-This is before lift and steps
Swapped out tires/rims for a 2021 Tahoe rim as I am not a fan of all black rims
Swapped out rectangular running boards for High Clearance off road step.
Added 2" factory GM lift.
Added aftermarket subwoofer under rear seat
Windows tinted
Aeroskin 2 hood protector
Lasfit LED Reverse Lights
ARQ Rearview mirror with universal home remote
Tow mirrors are in my garage and will be installed in next few days.
Edited by Brent D
This is after steps and lift (pictures to big to post in same post sorry) Gained about 5" clearance under mid of truck. Not sure if im gong to add a leveling kit or not yet. May also add more aggressive tires down the road but enjoying my 27mpg too much right now.
Edited by Brent D
How do you like the firewire? I am just about to stat adding my lights back onto my truck and considered these but havent seen them in person. I run a speedturtle, visor light, and some accessory lights on the sides but considered putting firewire on my sides instead. Short of drilling there is not a lot of options for side lighting on a tinted truck.  I guess would you buy them again?
I love them. They are very low profile, easy to install, and puts off great light. Between my brother and myself, we have probably 30 Firewire LED's on different vehicles. The only issue we have ever had is the inline fuse will pop easily. Firewire recommended taking it out if it is installed on a fused circuit before their fuse. It was an easy fix.
Box did you buy new badges or paint/plastidip those? I am contemplating doing this to mine. Thanks
Installed new leaf springs, cut some big holes in the bed, and installed the bedcage and new shocks. New setup should be almost twice the wheel travel as stock.
_20220704_102514.thumb.jpg.26ab150d61c32cf2eeeed73f6f4ecffa.jpg_20220705_115636.thumb.jpg.ebd401fd848ad693a34a18f4de67ca40.jpg_20220703_120408.thumb.jpg.19687aac748e910c7fd466b46fa90cd1.jpg
On 7/5/2022 at 4:12 PM, kodiakdenali said:
Modified my mode switch to put my truck in sport mode automatically on startup. So much better!
Please, please share this mod.  I would love to keep mine in Sport mode as I keep forgetting to turn in on!
I so wish the truck was like this stock! I love this modification. Unfortunately is wasn't the easiest thing in the world to pull off, but I did a pretty detailed video on how I did it here:
The project isn't 100% done yet, its kind of in a testing phase, but what's left is just cosmetic really. the functionality is working great and I love it!
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
