Dropped the GM cold air intake into my RST this morning. Didn’t even take an hour. ??
I debated between the GM CAI or the Rotofab. I went with the GM for its native design, and am happy I did. The install was super easy.
About to leave for the dealer to have my catback exhaust installed! Can’t wait to hear the total difference in a few hours. ???24B085FC-BE45-4ADB-B552-7F43C4C78752.thumb.jpeg.1065b5c11bd65ae343ea1e436bac6330.jpeg
  • Like 5
Nice! You have the 5.3? How did the CAI change the sound from inside the cab?
Yes, I have the 5.3L.
Honestly, I don’t think the average person would even notice a sound difference. Listening for it, you can hear a deeper growl under acceleration, but you really have to be tuned in to hear it.
I think the sound note is most noticeable with an exhaust package. So far with the stock exhaust, it’s hard to really notice it. IMO.
Just bought and got it ceramic coated. Going to pic it up tomorrow. Looking at this ENTIRE thread, I see a few things I’d like to add. Nice thread
  • Like 8
Nice Rig!
Detailed the truck for the first time
  1. Chemical Guys Clean Slate for washing
  2. Adams clay mitt with Meguiar's Quik Detailer for lube
  3. Meguiars M105/M205 cutting compound with Griots 6" DA polisher
  4. Meguiars NXT Tech Wax
  5. P&S Bead Maker
  6. Meguiars Ultimate Insane tire shine
That's just for the outside. Here some shots with the reflection.
4 hours ago, Sierra50BMG said:
New wheels and tires :))
Do you have a mesh cover over the grill? Or is that part of your bumper guard? Been trying to find a mesh cover I can put on when I drive from SLC to Vegas because the bugs are a magnet to my white truck lol!
It’s part of the Grille Guard. It’s a Westin HDX. it just protects the radiator from anything crazy like a bird or a cleat from a big rig
  5. P&S Bead Maker
All good but I actually found that armoralls tire shine is far better although I also added outlast break dust repellent over it and has lasted 4 weeks I was only get about a week with meguires ultimate tire shine so curious if the break dust would work over meguiars as well
Sent from my Pixel 4 XL using Tapatalk
3 hours ago, jgraves13 said:
Specs? Looks good
BFG KO2 35x12.50/17 on a 4.51 backspace with -6 offset. I also have icon 2.5 extended travel coil overs set at 2.25” lift with their tubular UCA with delta joint. I had to remove the mudflap bracket and cut a bit of plastic. Nothing crazy. I have a rub at full lock when hitting a bump or a curb. Other than that I think they looks sweet and they ride awesome.
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
