2 hours ago, AEmedic said:
Thank you.  They are Callaway wheels.
What kind of lift is that?  Looks good.
Fresh wash today... and unfortunately noticed I’ve got a huge nick in the black chrome coating on my fog light bezel... ugh....
It is the Trail Boss lift with 1” extra up front.  Just about perfect!
On 9/9/2020 at 11:02 PM, AJMBLAZER said:
Pics of said pooch in action.
On 9/9/2020 at 8:58 PM, romclean1 said:
Made a mini center chinrest for the dog !  she loves to stick her head out the "nose portal" when we go for rides, but every bump hits her in the chin with the window frame edge.  Can't let that happen to mans best friend.  Ordered up a spare center headrest and took it apart, cut down the foam, put a slot in it for the car seat anchor and then a little pleather cutting and sewing.   Pretty happy with the outcome, just enough to cover up that anchor and give the furry beast a chin rest.
IMG_3347.thumb.jpeg.2094c2473337176323fb9b7e0e5ce577.jpegIMG_3346.thumb.jpeg.3f0d6d5cf4ec9a1322bacd2bfb6de43f.jpeg
  • Like 6
  • Thanks 1
Installed some AMP Xtreme powersteps, was pretty easy.  There are plenty of videos on YouTube, so I didn’t take a bunch of install pics,.   I didn’t use the AMP led lights, I didn’t like the peel and stick and they weren’t that bright,  instead I used LED modules from LuxLighting.  They use super strong magnets, to attach the led module, which also acts as the heat sink.  I really like their design, and it was easy to swap out.  The Xtreme version of these steps is pricey, with dual motors on both sides it seems like it will be tough enough to handle the winter here in WNY.  The steps are super grippy, will be interesting to see if ice gets frozen in the channels.
Edited by romclean1
  • Like 3
1 hour ago, AJMBLAZER said:
Currently dogless but hard to beat a dog in a truck.
How about two dogs? Just spent yesterday afternoon vacuuming out the crew cab, pulling out the floor liners to hit with the hose and wiping everything else down.
Is the fog light bezel from the AT4 and up, something you can add to lower trims or is a completely different setup?
Picked up a Trail Boss Custom Saturday
10 miles on it when I installed the range AFM disabler !  I ordered the range before my truck was delivered to dealership.
  • Like 6
Finally got my truck dialed in
2” Rough Country Leveling kit
33x12.50r20 Venom Power Terra Hunter XT
20x10 -24 American Offroad A105
Perfectly level all around and perfect for daily driving! Rides super smooth and no noticeable power loss. MPG TBD lol
More pics: https://imgur.com/gallery/5C977eO
  • Like 3
Next on my list of mods is probably an illuminated bow tie for the grill and down the line AMP power steps
Looks great!
No pictures since I forgot to take any but I did install my mirror tap for my radar detector.  Super easy since I found the YouTube video.  Purple/white for hot and black/white for ground.  Bingo switched power.  Zip tied it down and I'm good to go.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 1,315 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
