I read that you opened the dash to install the 3usb charging system.  How difficult was that?  You must have some expertise with these type of installs as tapping into the existing systems, scare me a bit, lol.
Nope.
I do this once every 4 years with a new truck.  It literally takes 10 minutes to take the whole thing apart and have it laid out to work on.
7 8mm screws and a whole lot of body clips to pop loose.  Way too many in my opinion.
The toughest part is getting that bottom trim piece off.  For a piece of plastic that small it had 5 body clips on it.  It doesn't need that many to hold it in.  I removed the center body clip when I reinstalled it to make it easier to remove later on.
Grabbed a 19 Trail Boss Custom about a week ago. Wanted a strong base for an Overland build out. Love it so far. But a little hard to find Overland Parts. file1-16.thumb.jpeg.5fb9fab20cd145427964fb294896f740.jpegfile-25.thumb.jpeg.9a1174a7d27f18fbe10baf1fcf366f45.jpeg
  • Like 7
1 hour ago, Sir Squallywally said:
2019 Silverado LT Z71   with ARE Z Series topper
Looks great ?.  First I’ve seen of the new generation trucks with cap.
Tonneau and Bed Rug Done!!!
My wheels and tires came in today as well. Can't wait to get those new shoes on the beast!!
Mods Complete/In Progress
LED Tailgate Bar - Done
Quick Charge 3.0 Ports Front and Rear - Done
Tinted Windows - Done
Bed Mat - Done
Backflip Tonneau cover - Done
22 Inch Black Wheels - Arrived
Nitto Tires - Mounted on Wheels
Floor Accent Lighting - Installation Tomorrow
LED Bed Light Expansion - Ordered
Well...traded the '14 in, which was a GREAT truck.  I never experienced the new model year issues that others had with that body style...
But there are things the T1 body has that you cannot mod into those trucks (interior cab size, AC vents, etc)
So, here you go:
2019 RST CC Std bed Z71 with convenience pkg II.  Good mix of options.
So, here you go:
Standard bed FTMFW. Love it bro. Love painted bumpers.  Congrats.
Thanks, I appreciate it.  She's a big girl...
Already have tonneau cover and steps on order.
Need to update my avitar...
Edited by Vicarod
added info
On 9/25/2018 at 1:36 PM, z1boss said:
Picked up my special ordered 2019 Trail Boss about 2 weeks ago.  Loving it so far.  Lots of mods already.
Hey z1boss,
Just a heads up I've got a red trail boss lt as well and you can get the "Silverado" and "LT" nameplates in black too from the chevy accessory website.  Check it out.
27 minutes ago, eapatzer said:
Hey z1boss,
Thanks for letting me know.  I like the way it looks on ur truck!
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   1 Member, 0 Anonymous, 7,181 Guests (See full list)
