On 10/28/2020 at 4:16 AM, GMC207 said:
Ahhh only on Chevys?
you know whats funny is on my 2020 LT 2500 if i use the fob to try nd close it it doesnt close but you can hear a click inside the tailgate......like it wants too but its just disabled or something......on 2021 LT has this feature now i wonder if it can be added to 2020.......sure seems like the feature is already in there just needs to be engaged.....but maybe not.....its only $180 from chevy as an option so that means its a $20 part, lol
The click is the unlock mechanism. The motor that lifts it isn't there.
Sent from my SM-T510 using Tapatalk
easy to do or PITA?
There's nothing there for self closing. The click is the release operating. Only for opening.
Sent from my SM-A505U using Tapatalk
1 hour ago, Chevyguy273 said:
I’ve also just discovered after 6 months of ownership that the interior lights especially the front are useless. Who needs lights aimed at their crotch??
I noticed that too.  They are literally aimed at the doors with no usable light to the center.  I added this and replaced the bulb with a bright LED.
Nice, also like that sunglasses clip holder. How can I get these?
Ever received road head? Apparently GM thinks the girl needs help since people who drive trucks have tiny Ds.
Don't respond to that. I'm probably going to get into trouble with the moderators for posting this.
Seriously though, I've found it useful when trying to read a paper or something else that doesn't have a light up screen. I mean, who needs a light in their face? GM did use the dimmest 5000 Kelvin rated led lamp they could find for that location, though.
  • Haha 1
Love these sunglass holders!   Best ones I've found by far.   I got the double so I take my glasses off, stow them and pull my sunglasses off.
Single:
https://www.amazon.com/dp/B01BGZZ0DY/ref=cm_sw_r_cp_apa_fabc_pJSaGb88AXGT9?_encoding=UTF8&psc=1
Double:
https://www.amazon.com/dp/B00YVQD4A2/ref=cm_sw_r_cp_apa_fabc_gLSaGbVBNNXKX?_encoding=UTF8&psc=1
Yes I have. My college girlfriend many years ago on a road trip driving back from nyc to Maine somewhere on I-84 outside of Hartford, Connecticut at around 1am with her father passed out snoring in the backseat.
  • Haha 2
Um, I did say, "Don't respond to that". I think I can hear the ban hammer coming already.
  • Haha 3
Are the bulbs replaceable? In my 03 Duramax I got much brighter LEDs to replace the incandescent bulbs. It made a huge difference. I then got the same type that fit the mirror in my C6 Vette. It really sucks because being a convertible it only has the mirror lights. No place for a center light in a fabric top. That made a huge difference too but it still sucks. The one in the center of the roof in the 2020 puts out about the same light as a birthday candle behind a coke bottle. That's the one I would upgrade. The front ones would be a problem if you need a map light while driving. They would reflect off the windshield. They can't even be aimed. On the old truck the mirror lights and center light come on together so I upgraded them. The map lights are separate and can be aimed. That made more sense. I don't like that the map lights are part of the courtesy lights. Even on big trucks they are separate. Most have 2 on each side. One clear and one red to prevent reflection. Normally in one fixture on either side of the courtesy light. The courtesy light operates the way our map lights do when you push the lense. But GM went cheap on these trucks and made them dual purpose.
Single:
Double:
Any info on your map light ??
Here's the thread:
Light:
https://www.amazon.com/dp/B0000AYAEO/ref=cm_sw_r_cp_apa_fabc_M1ZaGbGVPEGEJ?_encoding=UTF8&psc=1
Bulb:
https://www.amazon.com/dp/B07H2CFSY3/ref=cm_sw_r_cp_apa_fabc_80ZaGb021384G?_encoding=UTF8&psc=1
I wired it to the unused harness attached to the headliner.
The bulb upgrade is very bright!!!
Edited by fsuboy75
If you unclip the sun visor, as if you were going to swing it to the side window, you can then pull it off the hinge side covering that little spot between the visor and rear view mirror.
It will block the use of the mirror, but I would rather see in what is in front of me than what's behind.
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
