Just talked to my dealer today, still waiting on new window. Have any of you seen rust under your back seat. I got plenty of surface rust on the rear seat brackets, some on the jack, and oxidation on most of the bolts. What do you think the dealer will say about that.  Mine is a Oct 18 build, but I did not purchase it until Oct. 19. It was probably wet the entire time it sat on the lot. Hard to believe the dealer did not know this.
  • Sad 1
I took pictures and videos of the truck before I dropped it off. I also received a 2020 Silverado loaner. Between the pictures and the loaner, I was able to verify the two different glass suppliers on the actual glass. The 2020 had the new supplier glass whereas my 2019 still has the same supplier glass before and after the replacement.
Can you post pictures or otherwise say how everyone else can distinguish the two suppliers? So what marking on the glass are the original supplier and what markings are from the new supplier?
55 minutes ago, PtownVdub said:
FUYAO is what is on my Oct. 2018 Fort Wayne built Silverado. I can't remember or find the picture of the name on the 2020 loaner that I had.
Where is FUYAO located? I have VIRTO in the lower right corner - if u are looking from inside out. I have a cap on the bed so I can’t really get a good picture from the360BFBD5-E85E-4180-B875-EF5A960859A6.jpeg.1344380afc414be6107fd95e1e3904f2.jpeg
how do u rotate pictures?
Edited by mistaare
Can’t rotate pictures
You have more corrosion than I do but my 2019 with the recently replaced rear window has corrosion on the seat brackets and jack.
Edited by PtownVdub
full sentences ...
FUYAO is located on the glass in the same place as VITRO. VITRO was on the 2020 loaner. As I understand it those are the two different glass manufacturers.
Now I’m curious to see if anyone has had leaks with VITRO.
Fuyao and vitro are two different companies. I believe fuyao is based in China but is a global company. Not sure about vitro. Pilkington is another big player in glass and have I believed are based in Finland and have facilities in Ohio.
My 2019 had a different design replacement window than the early build. The 2020 I have has the same design as the 2019 replacement. I know they were different but I don't know the names. My 2019 buyback had Rusty seat frames. That was part of what pushed me over the edge for a buyback when I said I wanted the seats replaced too.
Next post is lucky #1000 in the rear window saga
Sent from my Pixel 4 using Tapatalk
I found a picture. My 2019 early build had a fuyao. Which means the replacement window and my 2020 have the Vitro named windowbc845d9a59faddbc22bd4b0e0e1bb0ed.jpg
My replacement is a fuyao. Still not sure how I got it so fast compared to some on here. Maybe someone else was waiting for one and they mixed us up? I wouldn’t put anything past them. No leaks yet but I’m thinking I might need to take out the truck and flex it a little. To test the theory I can leak test before and after. It is an at4 after all...
    • I find it amusing the OP doesn’t realize this threads heading includes several engines. He should have posted in the off topic section if he wanted a more narrow focus. I really appreciate and find amusing that he actually pointed out one of my many vehicles. The Odyssey. That happens to use 0-20 oil. I love pushing his buttons.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
