Just left the dealer a bit ago and they offered me 74,750 OTD. THE STICKER WAS 77;900 and my county tax rate is 9.5%. What do you think. Is this a decent deal or should I keep looking??
I don't know much, but that's only $3k off sticker. Even with TTL and dealer fees, it shouldn't be that high OTD, unless you opted for some addons.
I don’t recall any extra addons but I’m in California so things tend be a little more expensive. Anyone with any insight on this please help as I’m looking to purchase ASAP. Thx
doing some quick math, taking the 9.5% tax away, your price was $68,265 with license, title, and dealer fees included. still seems too high. search this thread for your particular truck, there's bound to be someone who has a similar truck to yours.
Is this a 1500 or 2500? Assuming 2500 given the price. If so that’s not half bad. They’re barely discounting the HD trucks right now.
Looks like it’s about 12% off MSRP before TTL. I got around 18% off MSRP before TTL. I would shop at another dealer to see what they are offering.
I was looking at LT 2500 4wd and sticker was 49.9k and they would have sold it to me for 46.9k OTD with long beach tax (10.25%)
California is ****** but this was a 2500 which hardly ever gets reduced.....so a 1500 you should be well under 6k OTD from MSRP...
$6-6.5 rebate and 6k dealer discount....don't be in a hurry man, just shop around
A 1500 you can get 25% off MSRP. My sticker was 58 and i was 43 plus tax tag and title. I have not heard that the HD trucks, either ford or GM are anywhere remotely close to that though.
Just picked this up on Friday
I’m beyond envious. What did you end up paying before tax tag and title?
On 3/8/2020 at 10:01 PM, TVelar said:
Pulled the trigger today. I am very happy for what i got it for. 2020 Sierra SLT 4x4 with premium plus package in dark sky. Sticker was $58,500, vehicle discounted to 43,383.02 plus tax tag and title. Out the door for $46,835.50IMG_8278.thumb.jpg.344ecda312902acd186ac51c3277480b.jpg
Did you have a trade in or did you finance the entire $46k?
No trade. They offered me 5500 for my 2008 silverado. Sold it through autotrader in a week at 10,300. I put 20k down on this one. Financed 26 and change. Payment is 482 a month at like 2.69% through bank of america.
Looking at a 2020 Trail Boss LT. MSRP 58,135. They're selling at 48, 616. Dealer did offer more 1500 more on my trade in than 2 others. Any feedback? Thanks guys.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
