Belltech Performance Handling Kit
Go ask a Guadalcanal, Iwo Jima, or Okinawa vet to thank the Japanese for anything...
I know lots of veterans. Their motto is forgive don’t repeat. I guess you missed that the Germans and Japanese are allies now.
  • Replies 53
I’m well aware of what alliances we currently have.  Hell, the MG on the A2 and later Abrams is from the Germans.  Our “small” howitzer...  British.  That said, the old salts I’ve had the opportunity to talk to over the years...  Think Walt Kowalski in the flesh.  Grunts have a tendency to not be very forgiving of the enemy that killed their best friends.  While they might have the utmost respect for the enemy, it’s very hard for them to “like” them.  Your experience  may vary.
  • 5 months later...
Anyone ever try this kit out??
I would recommend a link setup for you. When rear in board coil overs.
Okay, I'm just going to take things in a new direction and leave the suspension on the truck alone for the most part...  Screw it.  I'll get the gonzo handling and go-fastness via a Gen6 Camaro SS with MRC.
That's boring
Just now, Nasty said:
That's boring
It's low, loud, and in the 12's...  stock...  I'm okay with that kinda boring.  LOL
Didnt know it was already low. but I can Tell you the twisted metal coilover kit helped my truck a lot with only an 800 dollar price  tag
The truck is factory.  The Camaro I'm looking at post ROK tour is what's low...  and pretty friggin' fast.
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
