I took my truck to the dealership, I told them what was happening and they did a re-calibration of the sensors, took maybe 30 min. All is good now.
Another perfect example of the half-baked gimmicks GM is putting into these vehicles.
just as you guys said...it didn't reset overnight like they said it would.  Appointment next week!!
   Going to talk with them and see why I was told that
   Thanks
Because they dont know how to read/want to get warranty work out of the way so they can do work that actually earns them money? Its not a dealer issue its an industry issue. Funny thing is, my buddy had the same thing except they DID reset his pad life when they shouldnt have per the tsb as he had more than 6000 miles
On 12/5/2019 at 6:44 PM, Hobey said:
Sounds weird after you calculate it and have tracked it....thanks?
I have a 2019 Silverado LTZ - about 6 weeks old. Mine is right there with ShamrockShooter. 10% for every 1000 miles (front); about 5% rear. Front would be out at 10K miles. I'm at 5,200 now; took it in for first oil change today and asked. They said "they're supposed to be working on a fix" but didn't offer any solution at this time.
Brought mine back in and got it recalibrated, this time it worked...took about a hour.
     Thanks
It's well documented already that this is a known software issue. For the people posting the "me too" posts, just read up.
Take it back to the dealer and they will fix for free.
Provide the TSB referenced several times in this thread as it doesn't seem like the dealers themselves are very good at searching for this issue if they weren't already made aware.
I had mine addressed months ago and I'm still sitting at 96/98 as expected.
I set an appointment for the seatbelt recall and also the brake % issue. I was told my truck is fine and there isn’t an issue (I take it in next Friday I was just scheduling). I’m sorry but 30% at 5200 miles is not ok [emoji2361]
Called and spoke to the advisor after work. He said the bulletin is for a Cadillac and no longer good for the silverados [emoji2361]also started mentioning they would need to check the pad thickness and such to make sure there weren’t any other issues. I was like if they have to do that just leave the thing alone
Soon I won’t have any pad left [emoji23]
He's incorrect. There are a handful of TSB mentioned here. I believe one of them was for Cadillac only.
I'm sorry you have a bad dealer/advisor :-(
Well he texted me back and they found it. Only applies to certain vins/plant builds supposedly
It’s going ok next Friday for the seatbelt recall figured I’d get this taken care of
Seems awfully coincidental it has all of the exact symptoms wouldn't you say?
On 4/24/2019 at 10:28 AM, RyanbabZ71 said:
It’s one of those things that was never checked maybe during break in the pads wear more. We lived for years without it, personally I will monitor mine but not freak out it’s kinda like the OLM nice to have but is it accurate.
Case in point on my Camaro in 976 miles on the current oil change my OLM was at 29% this spring when I did the oil change. Head scratcher as the oil looked real good still visually (car only has 1400 miles total). No idea why it dropped so much but I’m not worried about it
Ryan B.
The OLM drops over time as well as with mileage
I need to get mine done I’m at 5,000 miles and 43% pad life not as bad as some I’ve seen on here. I’m gonna get it done when I take it in for the seatbelt recall
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
    • Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
    • Knowing the life of your brakes is a highly important status to keep track of. If you suspect your brake sensors need attention, please fill out our support form with additional details on your experience. When did you last take it in for inspection? Our team will follow up with next steps as soon as next available. Please include your username and GM Trucks Forum in the form as well. Support Form: https://s.chevy.com/support-request
