Yeah You truck looks great Lapoolboy. Im sure it's tall. I test drove a LT trail boss before I bought my 2020 RST. I remember the bed was up to my neck. I"m happy with the 1.5 level in front and 1.25 in the rear. 1.5 shouldn't tax the front end components to much either.  It's just right. Still might get those Rought Country Leveling struts some day. Until then I'm good.
Up to your neck? Are you 4’2?
  • Haha 1
King 3.0 ibp coilover with 3.0 ibp rear. Ordered deaver 2” springs to get rid of the lift block.
  • Like 4
No comp adjusters?!
1 minute ago, TheTicketTX said:
No comp adjusters?!
Yes. They come on all 3.0. 2.5 you have an option to have/not have them.
2 inch Southern Truck Level (Lower strut)
20 inch Stock wheels
285 60 20 Nitto Ridge Grapplers (no rub)
Also took off Air Dam today(looks way better)
Edited by Jay Teez
  • Like 4
That looks great! Those wheels and that color look good together. How does the ride comfort compare to stock after the new tires and level? Also how does the extra tire weight feel with the 5.3/8 speed? I want to do something very similar to my truck, but I’m afraid of losing some comfort/power...Thanks!!
@ausomecasey
As far as comfort and ride quality there is no change, I actually like it better because your sitting higher and can see more especially at intersections.There is a slight power loss with weight of the tires but the truck still gets up and goes with no issues. It’s minimal. I’m very happy with my setup as I prefer a more stock look.
On 2/10/2020 at 12:29 PM, TheTicketTX said:
No comp adjusters?!
What wheel n tire did u choose..? The wheels look good, its hard to tell tho on the tires and the size.
Addict Xd wheels BFG 35/12.5./18
On 2/9/2020 at 2:45 PM, rodycomero said:
We finally got some sun to wash her up and take a picture. 2" leveling kit with KO2's. I've run this setup on all my trucks. Love it.
Nice ride. What’s the tire size? Block in the back?
