I've had my truck now going on 3 years this past 4th of july, ive been having issues with my USB port and 110v Plug not working tried using new cable for Apple Car Play and still no luck, i called dealership and was told i am out of warranty (of course) and have to pay $199 just for inspection ......... I Dont Think So. Does anyone else have the same issue and solution? Ive already checked fuses and all look good, might i also add that at times my screen goes DARK while the truck is on as well thanks.
Did your warranty just expire this July?  If so, I'd phone GM customer service and see if they can help you out. A well worded, sincere plea may get you a reduced cost of repair.   If your warranty expired a year ago, I'd see what the $199 includes.  Does this cost go towards the actual repair if you let them proceed with the work?
Don't just look at the fuses, pull them, and ohm them.  I've had a few that I didn't see a break in the loop, but they ohm'd bad.  I don't understand it, but it happened on a couple rare occasions.
I was having a similar issue, but with my DC outlets and my 110V.  Then one day, it just started working.
Damn GREMLINS!!!!
My warranty expired 5,000 miles ago :(
Damn GREMLINS!!!!
I’ll be sure to replace the fuses and see if it works, thanks for the info guys.
Two things to try.
First find your HMI and reseat ALL of the connectors on it. The HMI is behind and above the glove box. Second find your radio module and reseat the connectors there. This module is below and behind the screen.
This will not address the 110v outlet issue but let's worry about till after the other issues are resolved. It's best to concentrate on one issue first.
2 hours ago, rusty503 said:
Two things to try.
Battery disconnected right? Or just not have the key in ignition?
On 7/9/2019 at 11:02 PM, rusty503 said:
Two things to try.
+1 on checking the HMI first, especially since you are having intermittent screen blackouts...HMI controls the screen, usbs, SD card slot, bluetooth, and speech functions.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
