Hostile Sprockets 20*10 will require a 8mm spacer to clear the caliper, really bummed out about it, but oh well.  factory 275/60 Bridgestones mounted on my Hostile wheels.  Truck is stock height with just a mud flap mod.  0 rubbing at all full lock to lock.
SELLING MY CUSTOM HUBCENTRIC 8MM SPACERS IF ANYONE NEEDS A PAIR.
Edited by pewterliftedz
I'm looking at some 22x12's for my truck.  Anybody running these?  I don't want that "too wide look", but want a more aggressive look.
The guy who posted before you has x10s and they look like they hang out of the fender an inch or more so so assume the x12s will be an inch more than that at the minimum especially if the offset is -44 or similar.
Sent from my ONEPLUS A6013 using Tapatalk
22x10 -19 offset Fuel Contra
35x12.50 Nitto Ridge Grapplers
6” BDS
- Lots of trimming was involved to make it not rub so bad. Trimmed out the whole inside of the splash guards, the front wheel liner until the bracket and the bottom front valance trimming. Even after all the trimming it still rubs in reverse on the passenger side but my solution to that is make wider turns.
Edited by burban81
  • Like 5
6” BDS
Looks great!
My 10 wides hang out of the fender quite a bit, I can't image a 12 wide.  I'm actually shopping for a 9" wheel, because I'm not crazy about the look
92c247f54440c340b707de4fd00b828d.plist
These are x10s , i think it’s very minor.
For those that changed out the stock 18"s on the 2019/2020 Trail Boss, anyone happen to know the wheel specs??  I know they are 18 x 8.5 but I've tried searching weight, backspace and offset and can't find the info anywhere.
18x8.5.  26mm offset. 5.77 back space
Edited by Flatblack83
Factory Trail Boss 20s on my LTZ.  Ridge Grapplers will be installed later this week
Added 275/55r20 Nitto Ridge Grapplers
Thanks!  Happen to know weight of each wheel and where you found the offset and back space info?
On 1/16/2020 at 3:04 PM, Spenroe said:
Nice looking truck.  Were the side badge/vents easy to replace?  I'm looking at changing mine to those.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
