Apparently you can get OEM paint matched fender flares from GM.
Here is the video of them being installed:
Edited by ApertureX
6 hours ago, ApertureX said:
$650 isn't bad for all 4. Worth it to remove the plastic that will dry out and turn grey just like on the Chevy Avalanche.
They're available for less at some of the online OEM parts sellers.  I recall finding them somewhere for $510-ish.
36 minutes ago, cdh7917 said:
Added the painted flares.  Also tinted the lights while they were off.
Thats pretty sharp!
Do you have the website you found them at to share? I’ve searched but only find them on the go accessories site.
https://www.gmcertifiedparts.com/oem-parts/gm-molding-pkg-84545372
That is a link for the Dark Sky Metallic ones. I searched on accessories.gmc.com first.  Once I had the part number, I just Googled ‘gmc 84545372’ and found them from a few places. $512ish was the best I found.
You can do the same thing for the other colors too, hopefully you can find similar deals.
ok, appreciate the feedback, thanks.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
