'21 GMC WT, 3500, SRW, Crew, standard, gas,
Payload = 4,044 lbs.
Edited by T.O.
2021 2500 High Country Gas CC SB w/ deluxe, sunroof, snow plow prep, z71 = 3248 lbs of payload available
Edited by M Parr
Add bed / can config
Fwiw, there will be another label on the outside of the doorpost, down at the bottom, that has a bunch more info on it.
My 2021 Sierra Denali HD 3500 SRW Duramax (5th Wheel pkg, Denali Ultimate pkg, Black Diamond pkg, Rear Under-Seat Storage). Curb Weight 8,417 lbs. Payload 3683
My brothers 2021 Sierra Denali HD 3500 DRW Duramax (5th Wheel pkg, Denali Ultimate pkg). Curb Weight 8706 lbs. Payload 5294 lbs.
It makes no sense some of their numbers. Had a friend with a 14 2500 gas lt his payload was 27xx i have a 15 high country gas and my payload is 2680.
On 9/22/2020 at 5:31 PM, Njmurvin said:
Crew cab, standard bed, 4x4, LT 3500 Duramax - 3895 payload.
included goose / fifth package?    Soon I will order...
Yes!  Options include: Duramax, convenience packages 1 and 2, gooseneck/fifth wheel package, Z71 offroad and protection, leather package, hitch package and Autotrac 2-speed transfer case.
Thanks NJmurvin,        What about asissts step?
I had the dealer add the GM chrome tubular steps before I took delivery (and they're very nice).
those duallys have lot more......a gas version prolly 6k plus
for me its payload not towing, at least for now
2021 2wd reg cab dually payload:
gasser 7442 lb
diesel 6523 lb
2021 2wd crew dually payload
gas 6894 lb
diesel 5894 lb
for both:
GVWR 14000 lb
RGAWR 10500 lb
4wd payloads a little less, GVWR and RGAWR are the same, so weight of transfer case, front diff, front drive shaft and half shafts all reduce available payload.
Edited by redwngr
What size of wheel do you currently have?  18 or 20 inch?
    • I agree.   However, the owner's manual, suggests that a drop over full is just as bad as a drop under. (Read black and white letters only, insert no common sense.)
    • That P0700 and loss of power suggests something significant is amiss to me.   More/other codes may suggest otherwise; I would investigate those prior to spending the money to change fluid on a transmission with a bad torque converter.    The relatively sudden escalation of symptoms to me suggests that something began failing (initial shuddering experienced) and rapidly deteriorated (slipping/loss of power). Fluid condition alone wouldn't cause the sudden escalation of problems - though it might have been the cause of the deterioration up to the point of failure.
    • Stabilitrack operation is in a sense a separate/independent operation from the operation of 'traction control'. Stabilitrack is used to keep the vehicle traveling in the DIRECTION intended, it can brake independent wheels and or adjust throttle to influence the direction the vehicle is moving.   This can be illustrated by a 'fish-tailing' example. At high speeds, if the stabilitrack detects excessive yaw (the vehicle spinning like a top, it has a sensor for this), based on inputs from steering angle it determines that the vehicle is spinning out of control, and begins working to control that unintended spin. By reducing throttle input or braking specific wheels to control or prevent the spin.   The traction control works similarly using the ABS system to slow spinning wheels and thus transfer power to 'other' wheels. The goal being to achieve wheel speeds that are all in agreement with each other, the truck then assumes that since all the wheels speeds are the same no spinning is occurring. For example, launching up a wet boat ramp, there is no excessive yaw present, traction control alone can manage the wheel spin by braking spinning wheels and cutting throttle.   Stabilitrack and traction control from a hardware and software standpoint are basically one in the same, I don't remember specifically in 2004, but you couldn't get a truck with one and not the other. The switch on the dash, could turn off the traction control, but not necessarily the stabilitrack.    A confusing comment about stabilitrack vs. traction control, the same components serve both operations, but marketing could advertise them as two separate features.    The AWD system is another separate system entirely, in addition to the other two, it uses the same wheel speed inputs but can also vary the transfer case clutch application to direct some power to the front axle, working in conjunction with the traction control to bring wheel speeds together.   The power split will never be greater than 50:50, the same as 4-high. It will never direct MORE power to the front axle than the rear.
    • Not based on the new photos I'm seeing.  Car and Driver posted additional photos that shows an auto stop start button left of the steering wheel.
    • Car and Driver is reporting wireless CarPlay WILL remain, and they posted several additional photos, including a left knee shot, but the only hard buttons there are e-brake, auto start stop, tailgate and cargo light.  Also definitely looks like High Country and ZR2 get micro fiber on the center of the console lid and the ZR2 possibly also on the seats.
