I saw a few topics on swapping the Silverado 2020 LT 2500HD but they seem older posts from 2019.  We just bought our 2020 and love it but I want to change the lights to LED everywhere.  I went on Amazon to see but there are so many choices that I don't know where to start.  Who else has done this ? help please :)
Thanks a lot. How did you handle the problem where LED does not consume as much power and could impact the truck?  I naively asked my dealer thinking that since then they would have made something available but they were adamant that this could impact the truck and computer.
1 hour ago, stephane lamoureux said:
Has anyone been able to do the LED swap on their Silverado without the truck computer going wing nut.  I am told it is a power issue since led takes less power then the old bulbs...
You need to order the Canbus along with your bulbs.  The canbus increases the voltage signal to the trucks computer so you don't throw any codes.  The bigger issue (IMO) is getting an LED to work in a non projector beam housing so you don't blind on coming traffic..we've all seen this.
that's great. thanks for the info. This should help me a lot in finding the right one then.  I did spend time looking at LED for the non projector beam and found headlightrevolution.com do a comparison of LED and their beam issues and the GTR lighting ultra 2.0 (9905/HB3) came out on top though not sure if this has the canbus you mentioned.   If I find one that works better then other, I will post it.
I went with these for the high and low beams.
Fahren H11/H9/H8 LED Headlight Bulbs, 60W 10000 Lumens Super Bright LED Headlights Conversion Kit 6500K Cool White IP68 Waterproof, Pack of 2 https://www.amazon.com/dp/B07NPMV1H5/ref=cm_sw_r_cp_api_glt_fabc_2YD2RG7XK4YRBZVMZRB0?_encoding=UTF8&psc=1
And these for the backup lights.
Alla Lighting 912 921 LED Reverse Light Bulbs Extremely Super Bright 4014 30-SMD CANBUS 921 LED Bulbs RV T15 T10 906 W16W Back up, Cargo Lights Replacement, 6000K Xenon White https://www.amazon.com/dp/B072FHNZKW/ref=cm_sw_r_cp_api_glt_fabc_TRWF41QMYARNMZ38AC44?_encoding=UTF8&psc=1
So far no one has flashed me at night. Much better then the stock halogens. It was a pretty quick and easy install as well.
Did you have to use a canbus with the Fahren headlights? Or were they good to go as-is without tripping up the computer?
1 hour ago, Sledguyry said:
They were plug and play for me with no issues.
Thanks, just ordered the same as you for front low/high and the rear! How did you orient the front leds? I'm reading some people recommend installing them vertically, others at 9&3 o'clock. Don't want to blind other drivers and it sounds like you've accomplished that.
I installed them vertically. They are working great. I believe the instructions call for them to be installed vertically. The connection on the stock bulb orientated vertically as well.
I ordered the one you got as well. Has anyone swap the high beam and fog lights over? Which bulbs did you use?
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
