Quite a while ago, I bought a set of factory 18" rims from a midnight edition HD. I was planning to run 35x12.50x18's, but tire prices went up and some tires became hard to find. Finally, I found a good deal at my local tire shop on a set of Sumitomo Encounter AT's in 325/65/18. For those that don’t know, Falken tires are made by Sumitomo Rubber Industries Ltd. The Sumitomo Encounter AT has a lot of similarities to the Falken Wildpeak AT3W, which I ran previously and was very pleased with. The Encounter AT is a fairly aggressive all-terrain, with a 60,000 mile warranty and the 3PMS rating. The tread depth in my size is 20/32, which is about the deepest you’ll find in an all-terrain. The 325/65/18 has an overall diameter of 34.7” and a section width of 13.3”. They look huge compared to my old 285/75/17’s.
My suspension is completely stock, except for a 1.5" crank (7-8 turns) on the torsion bars and shock extensions. Much to my surprise (and delight), the 325/65/18’s fit without any additional modifications. They’re really tight, but they clear. They barely rub the frame at full lock, but I'm not worried about that. I’ll probably pull back my fender liners with zip ties, for extra peace of mind. They're very close when hitting a bump while turning. They look like they belong on the truck, and I’m quite happy with them. These trucks have a very blocky/wide body style, and a bigger tire helps fill the wheel wells and improve the overall look.
Here's a few pictures...
Looks great, my next tires are going to be 35 25 65 18's, ran them before, going back to that size,  those look great.
On 9/20/2021 at 2:03 PM, gearheadesw said:
How quite are those big AT's?
They're very quiet. I'm surprised how little road noise they have, considering how much rubber is on the road.
Looks great!! I was just at a 4 wheel drive shop here and they told me they don't recommend BFG 2Ko's for heavy trucks due to wearing out fast. Not sure if this is true but mine are wearing very fast. Not sure what to go with next but defiantly looking at your size!  How have they held up?
    • Looks tight. Not a lot of working room. Hows yous knuckles?
    • Spot on. The government makes ridiculous mandates, and this causes manufacturers to jump through hoops for every TENTH of a MPG. Main reason quality is in the toilet and prices are in the stratosphere.   The gov't tightened the MPG requirements so much 5 years ago that the only way manufacturers could meet these absolutely ridiculous numbers was to go all EV. Hence the push.     Nobody hates good MPG, Atlas - nobody is "whining". Your side has that trait all locked up. What a stupid argument attempt!   What I particularly hate is the government meddling in the free market system. Had this system been allowed to work as designed and intended by our Founders, cars and trucks would be hitting numbers that would blow our minds, all while costing 30% LESS. Not only that, but engines could probably hit 150k miles again without needing major internal surgery.   My forty year old Ford 302 has 312k on it. Wonder what changed?🤔
    • The BORA 3/8" spacers arrived yesterday along with the extended lug nuts. I got the front wheels changed out today, but was overheated and covered in sweat so bad, I figured getting both front wheels done was a win, and took a cool shower. Hopefully, I'll go out tomorrow morning before it gets into the 80+ temps and do the backs. After getting the first wheel snugged up, I backed out one of the lug nuts then hand turned to count threads. I believe I stopped counting around 12-13, so I think I'm good there.
    • My fullsize truck is averaging over 26mpg so I'm pretty happy with the increased fuel economy targets. When I had my gas Silverado (2020 5.3) it was averaging 21. Again, for a fullsize truck, that's very different from the 12-15 these things used to get 30 years ago.   Whine all you want, increased MPG is a good thing.
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
