I own a 2020 GMC Sierra 2500HD gas 4x4.  As with all GM trucks of this type, the chassis was dipped in wax to protect it from corrosion, however over time, some of this wax peels away ( or is chipped away), then surface rust appears.  Left unchecked, the surface rust takes over, and the next thing you know, you're looking purchasing a new truck.
Two questions:
1.  What methods are used to clean and stop the surface rust?
2.  What products are used to recoat the chassis following the removal and remission of surface rust?   Is there a compatible wax undercoating available from Bodyshop supply houses, or do we simply use off the shelf spray can undercoating (will it stick to the wax)?
This isn't exactly the correct product but it's all I have laying around but I use bearing and axle grease and pat it on the bare spots. You can buy aerosol cans of the factory wax but that ****** is like 60 bucks a can.
Daubert NOX is with that manufacturer uses.  I purchased a few spray cans of the stuff when I purchased the truck, and I use it occasionally to touch up parts of the frame where the vehicle lift contacts it.
  • 2 years later...
Even if we recoat the chassis with the correct wax type product, we still have the issue of surface rust and how to deal with it.
My initial thought is to power wash the chassis to eliminate any contamination, especially from road salt.  Even then the bare metal has residual oxidation that must be removed or chemically converted.  There are many OTC products that will work, but my experience is they're only asgood as your chassis is free from road salt.  If you coat with brush on latex or Permatex spray type rust converter, over road salt, you actually make it worse by locking in the Oxidizer.
When does this become an "exercise in futility"?
Edited by Z45
4 hours ago, Z45 said:
When does this become and "exercise in futility"?
Definitely is.
PB Blaster Surface Shield I used on a rusty Jeep frame. I did not do any preparation, and a year later still had good coverage when it was sold. Recommend reading the MSDS and using personnel protective equipment regardless of the product chosen.
First this...
shopping?q=tbn:ANd9GcSR6hWDPCItGJSF0OipLhmZ7xGPabM3S3LLWGZECXXbwjxp3kW8iVUy9AoknEJ3FjAHuVLEQSGgbwToCRL3MeCfufRa4IkwlWoxhkYNQt9bF2FXjkqVzd2r5H0
Then this...
Image 1 - RUST-OLEUM 12 oz. Roll Bar and Chassis Paint
Then apply the OEM wax coating...
IMG_4017.webpmasonk4566 · Mar 18, 2024 at 5:37 PM ·  View media item
Edited by Gangly
  • 4 months later...
I tried 3M cavity wax on my old 2014 Silverado and it didn't help with crap, probably because it was too late when I bought it after it was a lease and the rocker rusted through on the passenger rear at the bottom and the rear wheel wells were rusting through even though I flush them constantly and use the wax coating on it.
My current 2023 is nice and clean and only has a tiny bit of surface rust on the very front upper frame area where it's hard to reach for having it coated and I take it to rustkote for undercoating every fall before winter and it's been doing great. I also pull the wheel liners in the summer and fully clean the liners and the steel then wax it with carnuba wax and touch up on the cavity wax for any edges that are hard to wax. I do have to pay each year for the cavity wax but i'm not happy with the work i've seen done at krown and ziebart.
Rustkote does a great job for me with coating the bottom and inside the doors and rockers, my only complaint with them is they spray the inside of the engine where the cross brace and frame at the top by the radiator sits and it makes a mess of overspray and I just take a old oil rag to wipe up the excess on the plastics. They also try to wash the overspray on the body but it doesn't work and I always take the truck home and hand wash it to get the excess off the body panels and glass. You can hand wash but can't flush the underside and even where I live, the carwash doesn't have any underspray like they advertise so it will never flush the underside out.
AMSOIL's Heavy Duty Metal Protector works great for an undercoating or even touch ups.  I use it on my 2019 Silverado. It doesn't effect the factory coating.  If you want a quote for a couple cans let me know.
https://www.amsoil.com/p/amsoil-heavy-duty-metal-protector-amhsc/?zo=521390
    • I only have a few of the ACDelco blue remaining. One or two of the (old, old) ACDelco Professional boxes, and a couple of the newer style GM boxes with the simulcast in Chinese along with English. FWIW they've all been pretty good, regardless of where they are made, and in 20 years I've never had a problem with an e-core filter.   Now I have a couple of the "A" series in my home inventory. They come in a plain white box with the GM hologram sticker and model information. Have not installed one yet, want to use up my oldest inventory first.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
