2021 Silverado 1500 RST with 6.2, Push button start/stop.  I had one key fob, tried to program a second one. First locksmith could not get a fob to program. Got to the message that says ready to learn remote 1. Placed new fob in pocket between the cup holders. Press start/ stop button and nothing happened. Drove home and then the original fob stopped working. The original fob would not do anything. DIC kept saying no remote detected. Could not start the truck, etc.  called mobile locksmith, they worked for like two hours, using programmers, their fobs, the gm computer, etc. No Luck! Had trucked towed to dealership. Now five days later, the dealership can’t get anything fobs to program or work. Was able to get truck started once they said but nothing else.  Have had GM engineers investigating as well. Anyone have this happen? Any ideas? Bout ready to just wire a key type ignition in, lol..
This sounds like an upsetting concern, Jack. Our team would like to connect with your GM dealership to learn more, and assist however we are able. When you have a moment, please email us at [email protected] with your full VIN along with the name and address of your dealership so we can reach out. By sending us a message, you consent to the information you provide being monitored and recorded by GM or those acting on GM’s behalf, subject to the GM Privacy Statement: https://www.gm.com/privacy-statement.
After this happened to me, this seems to be a somewhat common problem relatively speaking.  I had this issue initially where it wouldn't recognize any fob and was stuck in the program loop.  I could start with app, but couldn't drive.  It ended up working after a couple of hours while a tow truck was on the way.   It turned in to a truck battery issue.
Some have replaced their truck battery and all was well.  Some have a battery drain by itself, or in conjunction the key fob issue.  There is a service bulletin about unexplained key fob issues with no apparent root cause found.  It discusses replacing the drivers window switch/control, the door latch assembly, or both.  Some have replaced the window switch alone and it has gone away.  I replaced the window switch since it's cheap and easy to do.
On the door switch, the theory is that a bad switch send the key lock/unlock signal over and over and puts it in program mode.  Some also attribute this to the battery drain since the system turns on over and over.  Some have said that holding the start button for 15 seconds will take it out of the mode and let you start.  When it happened to me a few times, I just disconnected the negative battery post and all was well until it happened again.  I carried around a 10mm socket.
Also if you have something in the OBD2 port, like retractable steps, start stop disable, etc., there are reports of this causing issues.
Lastly, which I think was cause of my issue, is the rear glass leaking.  There is a technical service bulletin about that too.  I had noticed that the battery drain happened when it rained.  I started digging around and my headliner was wet.  I found the leak and there are numerous electrical connections below that could have gotten moisture or wet and cause drain, which in turn could cause the key fob issues.  The frame for the rear glass is plastic and cracks.  There are two ways to fix, fill full of silicone or body sealant, or replace the back glass.  This is a known problem.
I'm hoping this fixed my issue and my battery was drained to like 5v several times, so I think my new battery may be toast.  It was low again the other day, but haven't had the key fob issue again.  By the way, the dealer had it for 5 days, couldn't find an issue, and several days later of course the battery drained.
Edited by scokill
  • So it turned out that the Theft Deterrent Module (TDM) or also referred to as Anti-Theft Module or Passive Entry Passive Start Module (PEPS) or just the Immobilizer Module was faulty. GM Part Number 13516352
    Then the new module required advanced EEPROM reprogramming to function correctly.
    (From web search) In vehicles, EEPROMs are integral to various control modules, including the Theft Deterrent Module (TDM). They store critical data such as immobilizer codes, key fob identifiers, and security algorithms. If the EEPROM within a TDM becomes corrupted or fails, it can lead to issues like:
  • Inability to program or recognize key fobs
  • “No Crank/No Start” conditions
  • Persistent “Service Theft Deterrent System” message
  • Anyways, it is fixed, and I have two new key fobs.
  • Quote
Add this to the list of things that can cause this.  Mine had no problems for awhile and now one trip to the car wash and it happened.  Went away quickly though.  Maddening.
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
    • I also need one of your modules for my 1993 chevy c2500 7.4 Thanks! My email is [email protected]
    • Chevy needs to do a black regular cab short box SS model with the new 6.6L.  400SS.
    • You might find the drive cycle you need somewhere on charm.li (website), otherwise I suggest a subscription to alldata.com to get them for your truck.
