295 each. You saw the normal price in previous pic. I figured to get them on sale while i can. Should perform decent out here and drop effective ratio to what it was stock.
It's crazy what tires cost now. The tires on both my truck and the Cruze cost more than the wheels.
This isnt really a common size either.
I payed 800 for my last set. Four 235/80/17 r500s
Oh yea that definitely doesn't help either. I think 4 of my Coopers were $670 with the rebate. 6ply LT265 70 R17, and i think the wheels were like $473 lol!
Anyone else have the center console latch break? Go to GM and be told have to replace whole lid. Then search ebay/amazon and find a replacement for 20.
I ordered a replacement latch off Ebay for $6 shipped. Took only about 10 minutes to change it out. Looked it up on YouTube and saw how easy it was, I should have bought more latches.
Scored these on Amazon for $13 each
Ryan
I have also ordered the replacement latch from ebay.
I would imagine it's probably the same one you bought because the price was the same.
I actually replaced the OEM's in both of my trucks after cracking, they don't seem to last.
The ones I received through the ebay seller seem to be of higher quality and are heavy duty compared to the OEM part.
The replacement latch should last a long time, longer than OEM I hope.
The first time I broke the latch in my 2008 I replaced it with an OEM latch I received at my dealership, got it free of charge. Unfortunately it didn't last so I searched around and found the heavier duty latches on ebay for a fractuion of the OEM cost so I ordered a few. I expect them to last but if not, I am not going to go broke ordering more latched at the cost around $5-$6. GM charges way too much for little parts.
Edited by BlackZ71Silverado
Got a hold of 15 qts of Dexron VI transmission fluid...free. So last night I pulled the plug on the pan and changed about 4 qts out. I'll let that run for awhile and then do a pan drop, filter change. Another step closer to getting this truck road trip ready. Also topped off the front diff, eventually I'll need to replace the axle seals but it doesn't leak too badly so I may not bother fixing it right away.
Pulled the trigger on these finally. Going to install them, and replace my rear block with a set of helper leafs I have laying in my garage.
Edited by Daryl Z71
    • I have changed oil and filter for years by starting a cold engine to warm oil up, let it run 5-10 minutes depending on temperature. Drain until it starts dripping, refill with quantity from owners manual or get it close.
    • I changed the factory fill oil in the rear diff of my truck for the first time today and the miles is close to 9000 on the truck. There was a lot of fines on the magnet, a very thick layer but working it through my fingers it all felt like mush and as most know it appears like graphite, so no surprise chunks anyway. Certainly was time to do it from my thinking and could have been done sooner but the oil didn't look awful but sure wasn't new looking and never expected it to either. I did use some solvent to help me clean out the bottom area of the axle housing, just get any other stuff settled at the bottom washed and wiped out of the housing for the bit of effort it takes. I used Amsoil Severe Gear 75W90 in the easy packs to try out what they are like and I used up 4 packs and didn't spill much at all in the process but did take all four of the packs and go to the work bench and emptied them into a measuring container and there certainly was some in them that added up to something, then poured that into one of the easy packs and squirted in what I could get out of it. I would say the level is within 1/8th of an inch of being level with the threads at the fill plug so just the perfect amount. Once again, more than what GM says the fill volume is but computes with what others are adding to their rear diffs as well.
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
