Pretty sure a 55w kit is too much for the capacitors to handle. Try removing them and see what happens
Sent from my SM-N910T using Tapatalk
I agree with Corwest. Sounds like a harness issue. Try opening the relay (just remove the black plastic cover) and see if there is somehow already rust or anything holding the circuit on when connected to battery. I had to do that for my LED bar harness. It started rusting a little from a week of heavy rains and a bad position in the engine bay where it got water. I just disconnected the relay itself and put it in a cup of 7-UP. I find that works better than coke or anything to clean battery acid build up and corrosion. It looks like a brand new relay after. I had this same issue with my light bar btw, that's why I suggest open the relay and see if anything looks wrong in there.
I spoke with TRS and they're sending me another relay and cap link. I'm going to swap them on Wednesday once they arrive. It's about 50/50 that they don't turn off as I drove home and they were fine once I shut the truck off. I'll keep you guys posted
has anyone had problems with the DDM tuning HID kits not working properly? First the driver side bulb would not ignite intermittently, if i manually turned the headlights on/off it will ignite but if I start the truck in the dark it will sometimes not light until i turn on/off manually. This is happening more and more frequently.
Then yesterday I could not get either bulb to light no matter how many times i turned them on/off manually. (It was cold and the truck hadnt been started for 2 days) After being in the Auto setting, engine running, for about 10 minutes they both finally lit up....
Anyone have any advice/similar problems?
HID kit has been installed problem-free (until now) for almost a year
My Morimoto kit is acting very strange. First, it didn't want to turn off when I turned the vehicle off. This is still an issue, but only happens 50% of the time. Now, the HID's do not light up when I hit the unlock button (they previously turned on for 30 seconds or so). Also, they are not on as my DRL's, but have been on in the past. I could hear a buzzing sound when I had my truck on, and the lights in "auto" position (HID's were off at this time). As soon as I turned the lights to the On position, the buzzing stopped. Very peculiar issues.
Can anyone with Morimoto's chime in? Do yours turn on when you hit the unlock button? Do they run as DRL's, or is there something in the relay that disables this?
New to this but it would probably help others help you if you add details about your kit since the 55 watt and 35 watt install differently. Sounds to me like you have 35 watt and the capacitors are not doing their job since it only has Issues with what they help correct.
If your relay or capacitors are shot then you will experience these issues. You need a working relay to turn the lights on and off when they are supposed to and the capacitors to stop the buzzing when they are actually on. Start there. Couple of us mentioned the relay a page or two back. Did you check it?
Edited by corwest
I've got a new relay and capacitor link coming tomorrow - Just thought I'd ask and see if it lead us anywhere different. Hoping the new relay fixes the issue, I'd like a working set of lights!
I'll bet it fixes it. There really is only a few components that could be causing the issue so start with the cheapest first
id love to find a company and have them respond offering a full retrofit done. I just don't trust myself doing all this lol
I'm sure there are companies that would do all the work for you. Someone is selling normal lights on here so you could keep a working truck and send those off. If you get LTZ lights it much easier and I'll be able to confirm this forest hand as soon as I get time to do install.
I have a set of LT headlights for sale... $375.00 plus shipping..
I installed the new relay and capacitor, and so far so good. Haven't had any lights stay on or flash like before. It's only been half a day, so I'll monitor it for the next week.
Just wondering, do your HID's stay on as DRL's, or do they turn off? I was driving in to work today, and pulled up to the building and my HID's were on while it was light out. I put the truck into Park and they turned off. Is this a normal function? I've never really noticed it before, so it could be me questioning something that is really nothing. Regardless, I want to make sure I've got my I's dotted and T's crossed before I say it's good to go.
What package level is your truck? SLE w/o the LEDs, your HID's will be on as your DRL's. SLT and Denali, your LED's are your DRLs and HIDs come on when it gets dark.
Edited by Kerrslight
    • Are you using a weight distribution hitch system with your trailer as that alone can change the actual tire pressure requirements needed. It would prove interesting to see what the actual individual axle weights are on your truck when you are hooked up to the trailer. In fact when your hooked to the trailer, typically if anything unless it has a large capacity weight distribution system that is over cranked, often the weight on the front axle will be less when hooked up vs driving empty and certainly if one doesn't have a weight distribution hitch. Really the only times one may get up there with weight on the steer axle is if there was a snow plow mounted on the front or a motorcycle on a rack or with a very large jockey tank full of fuel at the front of the box that transfers a bit of its weight to the front axle.    And of course your tires carry more weight for a given tire pressure due to their size vs a stock sized tire so there is that to take into the equation as well.
    • Great info here thank you. I just joined, we have a 2014 Silverado truck we bought about 4 years ago with less than 5,000 miles on it. It has approximately 24,000 on it now. It appears to have all the standard issues that people are talking about. Occasional charging problems especially using 110 volt, occasional blinking triangle where nothing will turn on when first starting the truck but it will reset itself if you wait 10 to 15 minutes. Noisy coupler between the flywheel and the generator. Our truck is speed limited to 74 mph, is there any way to change that? The latest issue we have been dealing with is when driving long distance on the highway at full speed the generator does not keep the batteries charged. The meter will go into the yellow/red border Zone for charge status and the yellow triangle will illuminate solid but the generator will not keep the battery charged, not sure why the controller doesn't tell the gas engine to increase RPM to increase generator output it usually stays well below 25 kilowatts even though the battery is discharging and I have to slow down the highway to 45 mph and eventually pull over and let the truck idle to charge the battery so I can continue driving at speed. Has anyone had this issue before or have any idea how to diagnosed it? When via Motors was around it they were very helpful at troubleshooting. This becomes much if the Terrain is hilly and you're towing a small trailer
    • I have the GMC accessory (REV) cover installed by dealer. Ordered with the truck.  They did a very good install job, can't find a single issue. Some water gets in around the tailgate but no where else.  You can see daylight around the tailgate but that's not the covers fault.  Installation is means everything. Guys at my dealer were seasoned pros, not inexperienced here today good tomorrow types, like many dealers employ for these jobs.   I don't mind paying for a professional job.
    • Like others have said, they will all leak. Mainly at the corners.   I have owned several and the best has been my current one. Revolver x4
    • About 8 months after an alignment job by the dealer I started experiencing a pretty significant clunk in the front end on hard left hand turns usually parking lot speeds almost at lock.  Occasionally get the same on hard rights too.   Discovered that the lower control arm attachment bolts are TTY and only to be used for a single use. And then I found some evidence of a TSB that indicates you can over torque those fasteners to about 130 foot pounds.   Asked a local shop to investigate and they found 3 out of four bolts loose and retorqued.   I've ordered the MOOG    K100421 lower control arm bolt kit that is completely reusable and not TTY.    Is the 80 ft pounds a realistic number?  Anyone have experience with those bolts?
