Yea a 1 inch hole though the dust cap. Put the grommet in and seat the bulb, connecting the bulk plug inside the light to the adapted in the grommet. You'll only connect that adapted on one side so don't worry about the dangling plug when you do the side without the wiring harness on it.
Other than that it's easy. Mount your ballasts and relay assembly upright to prevent water damage and dielectric grease your connections.
Test everything a dozen times before assembling lol
thanks a lot
Hey bud. The only issue you are going to run into is that you can not get the oem projector out the back of the headlights. ...........Your bracket looks good so far. I would be happy to sell you some of the FXR brackets I have made up. I have a 3d printer in my shop and can make other parts if you need. I am not a registered vendor on here so I don't want to come off like I am trying to sell stuff. So i will leave it at that. Lol.
Could I get a pic and price for the fxr bracket pls.. Do these brackets require complete dismantle of the headlight or can they be installed from the back like the other retrofits have been performed? What are the brackets made of?
Checked DDM-Tuning's website tonight and noticed they have a new kit available, it's called "DDM Ultra HID Kit" http://www.ddmtuning.com/Products/Ultra-HID-Kit
Anyone have any experience with these hid kits?
They're using "Osram CBI Series HID bulbs to produce up to 20% more light than a standard HID bulb and 50% more light that many HID bulbs on the market which allows you to see further than other HID kits"
Edited by arkenzo
So many issues on here. Is it the whole "no one bitches about the good" theory? Or do these just all have issues?
My pnp hid kit from retrofit source works perfect. Never had an issue yet but it is only temporary until I can get my retro fit done
I pick up my prototype tomorrow. The quality of this part can't be much better printed in plastic as he has some top quality machines, but the cost is to much with this guy. But, I want to know it works so I had this guy make the first one anyways. I am shopping for a more reasonable options in hopes it needs no revisions, but even if it does it's hopefully not something that needs another test.
My only issue so far is mechanical. I didn't want to crank down on the plastic to hard and wasn't snug enough with one projector so it shifted an inch at 25 feet. No electrical issues.
Edited by Crf450r420
They are weasel wording. They don't specifically say they are Osram bulbs. I'll put dollars to donuts that they're Chinese bulbs.
"The HID Bulbs are based on the Osram CBI Series HID bulbs to produce up to 20% more light than a standard HID bulb and 50% more light that many HID bulbs on the market "
Edited by spurshot
You're right, totally missed that, I might just buy the 55w kit to try out, we will see. Do you think these could possibly be any brighter than standard 55w ballast? They claim to be brighter than standard hid ballast kits...
since I park inside my garage, every day I leave in the morning (daylight) my headlights stay on until I drive up the street and then they turn off (due to Auto lights). Would this be bad or reduce the life of the HID kit? (I don't have a kit yet)
I know I could turn the Auto switch real quick to turn off the lights, but then that also turns off the LED running lights, which I would prefer to keep on.
If you're really worried, put the parking lights on before you start it. My outlook on it is just let 'er rip.
You have a 2 year warranty. Mine are on at night and when I'm in gear, plus when shadows kick on during the day.
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
