I tried this a few months ago with not much luck. The projectors in the replicas must have different mounting specs than the projectors in the OEM LTZ headlights. The brackets from fast headlights are designed for the OEM specs. I had the FXR projectors in the replicas, but they were not secure as I wanted them and you have to do some flexing on the mounting kit. I picked up a used driver side OEM LTZ headlight and the kit went in must nicer.
Hmmm, thanks for the feedback. Did you run the replicas as they came with HIDs at all? Just curious what the projectors that come in them are like. And when you say they weren't as secure as you wanted them...did you have at least 3 screws in? Or did you not feel comfortable with how you had to flex/adapt? the mounting kit?
No, I didn't even run the projectors that came in the replicas. I already had my box from TRS with the FXRs and the D2S bulbs and took the replica projectors out as soon as I got the headlights. I think I may give them a try though. I could only get the bottom two screws in the fxrs with the adapters. The bottom adapter needed to be flexed as the mounting holes in the headlights were closer together. I actually broke one and had to call to order another. The projectors flopped around since there wasn't anything on the top side to hold them down. I didn't want to go too tight on the bottom as that is how I broke the one adapter. Also, the metal in the replicas are cheap pot metal or something. I successfully cracked the metal on one of the screw mounts. I wasn't going gorilla on them as I was being very diligent with the lenses and all. Since I had so many issues, I ran the setup for a couple weeks and switched back to stock housings until I find another option to run the projectors. Still looking for a good deal on a passenger side OE housing as the driver side one I have setup went well.
I have finally finished reading this thread and the 39 page led fog lamp thread and with the shear number of different combinations that have been mentioned..... My brain hurts.
I am getting the SAE approved Rigid D-Series fogs and a 9012 Morimoto Elite HID system... But should I get the 4500 or the 5500. I am trying to match the fog with the headlamps.
Any advice/help would be greatly appreciated.
Well I emailed TRS to inquire if they have delayed powering relays as I would prefer a slight delay (10 seconds) before the HID's were powered on. Anyone know if these exist if I were to use a TSR Morimoto Silverado Spec System?
There is some drilling involved and the rubber grommet that comes with the kit doesn't really fit because the bulbs stick thru the hole in the cap. At least it did on my 15 LTZ. I didn't realize this until after I had purchased the kit. I just recently returned mine because I'm like you didn't want stray to far from factory just yet considering I just bought the truck.
Guys, buy the $100 each custom made deeper caps to allow your HID system to be as OEM as possible. This is the route I plan to take. I'm not cutting anything. I'm not doing the retrofit until I find another set of LTZ headlights to mod. I want to have a stock set for the next 3 years/36K miles just in case... Links to the caps are in the huge thread somewhere. Expensive but worth it.
Edited by DAP56
This is so freaking helpful. Thank you for posting about your experience. I have had the knockoffs in my cart for days now. So glad I didn't buy them. Sorry for your experience.
Where did you find the deeper caps? My google foo must not be working because I couldn't something like that. That would be a game changer.
Here's the link below. I can't remember what page these are on in this posting. Expensive, but worth it. A few members have tried these besides the member who designed them. I believe these caps may even have clearance for an LED bulbs with the fans on the back. I'm not sure if anyone has tested that yet or not. You can buy two of these for $160, or pay $65 for an extra OEM GM set, and have to drill them out and then try to water proof them. I would prefer this way.
What I would really like to see if someone has modified the ANZO "U Bar" headlights with FXR projectors. I'm willing to bet they too are cheap pot metal like the OEM knockoffs, and it is doubtful the FXRs with adapter would line up properly.
My LTZ has 250 miles on it, just drove for an hour in the dark tonight. The stock lights are TERRIBLE, the shadows kept making me think there was Debri in the road. Even my wife thought she saw things in front of us. The funny thing is, the halogen 5202 fog lights put our more light than the H11 projectors. Sad face.
http://www.shapeways.com/product/FTQHHLVEP/one-thinner-extended-silverado-headlight-cap?li=more-from-shop&optionId=56102883
It took me about 3 hours to install TRS Silverado spec kit on my 2014 LTZ yesterday. If anyone is on the fence about getting it they are definitely worth it.
It took some time drilling the holes in the dust covers in the right spots so the grommets fit right behind the new HID bulb connectors correctly.
If you take the 12 clips out and removed the plastic cover over the radiator, then you can run all the wires under it and ends up being a very clean install. There is also a place where the relays fit perfectly. I didn't do any drilling just installed ballasts with Velcro and a zip tie to help support them. Below is a few photos of the grommets installed and the relay location.
Good luck to anyone else that gets this kit and if you have a questions I'll help best I can.
Those fog lights are a clean bright white, so you will not want the 4500k lamps. They will have a hint of yellow and be closer to the stock bulbs. You will want 5500 or even 6500 to get that LED clean white.
If the projectors that come with them are not bad, it still could be a good way to go. The D2S bulbs are really powerful and put out a nice beam. I coupled mine with the Matsushita Gen V ballasts from TRS and glad I did. The 6000k bulbs are a clean white and lay down and good beam. Could be the FXRs that make it look so good, though. I was too busy this weekend to try out the replica projectors, but plan on doing it soon. If they don't work all that good, I will see if I can figure out a way to make the FXRs work.
Thanks for the tip. I ordered the 35W 5500 to go with the Rigid fogs. I also ordered LED cargo and reverse lights and some diodes to do the jumper so the fogs remain on with highbeams and cargo/reverse.
Thanks again for the info!!
Edited by OldDawg45
wow... just like a previous postyer my head hurts from reading about 30 pages today on this...
So i have a 14 silverado with projectors.. yes they are terrible.. i want to install the fxr 3.0 projectors and would like to do the least amount of drilling possible.
i reached out to TRS and this is the kit they recommended:
http://www.theretrofitsource.com/complete-retrofit-kits/bi-xenon-fx-r-stage-iii-kit.html
FX-R 3.0 Bi-xenon projectors (LHD)
Morimoto Ballasts
Morimoto Bulbs
H11 Relay Harness( you will also need the capacitor link here: http://www.theretrofitsource.com/components/harnesses/capacitor-relay-harness-link.html#.Vei6qn_BzRY)
Shrouds(Not needed)
a couple questions though..
1. is this kit only for the low beams? would i need a separate kit for high beams?
2. would the headlight extended cap that a member created be needed so i wont have to cut anything?
3. do I/would I need anything else for this upgrade? my goal is to have HID high and low beams and fogs - Which i see the HID Extra 5202 HID fog kit will work pretty good.
sorry for all the questions im just new to HID and trying to figure it all out
After installing a retro fit what are you guys doing with the low beam bulb? Is it still beneficial or does it just set there looking happy?
Hey OldDawg45 - I feel your pain. Been reading up on this for about 2 weeks before I'm ready to pull the trigger. This is the combination of HIDs and fogs that both Morimoto and TRS suggested for a '15:
Morimoto Sierra Spec: Morimoto Elite HID System - 5500k KIT The Retrofit Source
http://www.theretrofitsource.com/hid-systems/morimoto-elite-hid-system-sierra-low-beam.html
http://www.amazon.com/Morimoto-Elite-HID-System/dp/B013N20NSU/ref=sr_1_1_m?s=automotive&ie=UTF8&qid=1442849575&sr=1-1&keywords=9012+Morimoto
http://www.morimotohid.com/hid-systems/morimoto-elite-hid-system-sierra-low-beam.html
Morimoto GM XB LED Fogs 50374
http://www.amazon.com/Morimoto-Type-LED-Projector-Light/dp/B00XA3C0FC/ref=sr_1_fkmr1_2?s=automotive&ie=UTF8&qid=1442852322&sr=1-2-fkmr1&keywords=Morimoto+50374
http://www.morimotohid.com/complete-headlight-fog-light-housings/morimoto-xb-led-fog-lights-type-gm-h16.html
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
