capacitor to eliminate flicker and relay to take load of HID system instead of over loading stock headlight wiring.
Ok, so both are recommended for each kit then, correct? Headlights as well as fog lights?
Yes you could go with. Both I don't know much about opt7 my canbus system from ddm is a 35 watt system and it has everything built into the ballets and I didn't need the relay harness on my 15 Sierra it doesn't hert to have it
I have tried putco led headlights and opt 7, no problems with installation, but the get dimmer over time (as many led's seem to do), additionally, visibility in rain was awful. I am now on morimoto XB's (4500k), a vast improvement.
Has anyone swapped out the new 2016 Silverado HID's with TRS HID's?
I just completed an adapter kit to do just this. Email me at [email protected] and you can try it out.
Sent from my SM-N920V using Tapatalk
Edited by FastWS6TA
So back in August I installed FX-R's and Mori HIDs. Instead of baking the lens off I cut the housing open per FastHeadlight's instructions. When finished I used 4" wide roofing repair tape (the aluminum backed mastic tape) to wrap around the housing and then even used a torch to heat the tape to the point that the mastic was almost starting to melt and really pushed it down all around to get a good seal. I then drilled holes in the dust caps and installed the TRS supplied grommets. The issue I've noticed recently is that whenever it has been raining or early mornings that the windows are fogged (so high humidity conditions), the inside of the headlight lenses are fogged. It goes away a few days after the rain has ended. I feel good about the seal around the housing, but could that much moisture really be coming in around the grommet in the dust cap? Has anyone else noticed this after a HID retro? There's no water droplets, just a fine fog that the heat of the light burns off in the center. I would think having any moisture in there would be detrimental to the life of the bulbs. Something to worry about?
So despite having an led's powered by a seperate relay harness kit I broke down and installed the Morimoto Elite hid kit today, 35w ballast and 5500k bulbs, have to admit they are what everyone in the forum claims...needless to say I am suitably impressed!
Further to that I like the five year warranty too.
Edited by Comscan
If you want brighter light go with a 50Watt ballast instead of the 35Watt. The bulb rating affects the color of the light more than the brightness. The Retrofit Source sells Morimoto kits online. I just installed one and it works great. Get on their website chat line and they can point you in the right direction. Ask the guy on the chat line for a discount code and you get 10% off.
Edited by vacuman
Get some.of these and put them in the headlights. Even a little humidity inside the lights can create fogging. A drop of water turns into a lot of fog when it evaporates. These packs will absorb any humidity in the lights.
https://www.theretrofitsource.com/silica-gel-moisture-packs-48728.html
Got them on order. Thanks!
I installed a Morimoto 35watt 5500K HID kit from The Retrofit Source a couple of days ago. I just got back from a 200 mile freeway trip from Vegas to Ca. 3 lane interstate through the boondocks.
These lights are freaking amazing! Excellent clear white light across 3 lanes and 15ft to each side and at least 150ft ahead all without annoying other drivers. The whole trip on low beam. No need for HB at all. I did this same trip a month ago with the stock flashlights and was convinced I had to do something.
Best money I ever spent on a vehicle.
Edited by vacuman
Well, add me to the list. I just installed the Morimoto HID 5500k kit in my Sierra. I also installed the Morimoto LED fog light replacement kit. [emoji15] WOW.
The fit and finish was definitely as professional as others have described. The color and beam pattern is fantastic.
14fc96350bc995812d9589c347def4ef.jpg HIGH BEAMS AND FOGS.
a9a32ffc2905d6690a7ba9ac43f9d472.jpg LOW BEAMS ONLY
eeec98b8d625a25b5fef82de13c4ef3e.jpg FOG LIGHTS ONLY
1f0e1d75699c60e247376a50f219bca0.jpg LOW BEAMS AND FOGS FACING OUT FROM MY GARAGE.
My only question is on the last photo, notice the two "high spots" of light. Any input on why that is occurring?
The light pattern looks similar to the one I just installed. I don't think it's an installation problem. The bulbs can only be plugged into the harness one way and inserted and twisted into the headlight one way. I think it may be a reflection off some of the chrome trim around the grill. Beats the hell out of the stock ones though.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
