The kid must just be new cause iv had a inspection license for almost 20 years and all we have to do is make sure the lights work and are aimed right we don't care what bulbs u have or anything I have never herd of anyone failing a car due to its light being after market or stock
HID's in a reflector housing is an automatic fail.
They were in a projector tho.....how could the guy tell it came with a halogen behind the projector and not a hid? weird man
You might not have heard of a car failing but that doesn't mean it shouldn't. He is right - all lights that pass DOT testing MUST be marked with DOT approval somewhere (most are molded in the plastic lens but a sticker on the rear of the housing is allowed too). Also as Chev-mekanik said above an HID (and most LEDs) in a reflector housing should not pass either.
I'm not trying to start a war, just telling you what the law says. You're right that most shops won't bother to check and won't fail a vehicle unless the lights don't work.
Nope.
Technically they're all for "off-road use only". Not street legal unless they are DOT/SAE approved for street use.
Edited by cbrsilv15
To the GMC SLE guys running HID's, I ran a 35w morimoto kit in my SLE for a little over a year with no problems at all then all of a sudden my drivers side bulb and ballast burnt. Is this something I should expect being the SLE lights are on all the time? Loved the lights just don't want to have to replace every year.
Sent from my SM-G930V using Tapatalk
Every time you get in your truck turn the auto lights off that's what I do and it seems to work that what I was told by a friend and he has had his hids working for 2.5 years now
I've had the same kit for 2 years, no issues. I never bother turning them off, just let them run. 39,000 miles and about 1400 hours on the engine, so they've been on that long. Did you jump start your truck by chance? Do anything with the electrical?
No never jump started engine. I have a sub and amp installed but I had that before the HID kit. Don't see why that would affect headlights. Not one for having to turn off auto lights everytime I get in my truck. May give the HIDs one more try maybe the kit was faulty or something.
Officially dying for some HID's in my 2015 Sierra SLT. Which to choose which to choose.....
Have had my Morimotos in for about 2 months and love them
Just don't buy cheep ones from Amazon some of them are ok I have a 15 gmc and have had my DDM tuning ones for months now if you go with them there about 125.00 for the canbus system no power relay needed just plug and play the capacitors an error eluminator are built in
Also the morimotos are very good never had them but a lot of guys on here love them iv used DDM for about 8 years now and never had a problem
I've had both DDM and Morimoto, and hands down the Morimoto have a much better build quality. Don't get me wrong, the DDM never gave me issues on my 02 Silverado but the Morimoto kit is much higher quality, I just felt better putting it on a 50k+ truck
Looks like Morimoto is about $170? However I hear the DDM is overseas and leads to longer lag time should I have an issue?
Any group buys going for Morimoto. I don't think I'm going to skimp. I'll upgrade fogs too.
Edited by Aaron1085
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
