2010 GMC Sierra A/C blows hot air on acceleration
philmitchell
2010 GMC Sierra 5.3L V8 FFV 6-speed Automatic 6.6 ft. Bed - 17k miles
My truck above - when I accelerate, many times the a/c goes to blowing hot air. If I am cruising say at 65-70 and speed up any at all the a/c immeadiately begins to get warmer. One dealer I called told me that this is a built-in "feature" to give you more HP on acceleration - I doubt this as the compressor doesn't pull that much.
In the "olden days" this was caused by a defective a/c module in the dash, which caused a sort of vacumn leak closing of the intake vents.
What would cause it on this truck and how do I fix it? If it is some kind of design feature, how do I override it?
Thanks,
Phil
There is programing in the pcm to temporarily shutoff the a/c. It's to keep it from overspeeding the a/c compressor. When I tuned my camaro it was based in throttle position and on the corvette it was based on rpm.
I thought it was only supposed to cut the compressor when the pedal was mashed to the floor .... 100% throttle in other words. I haven't an answer for that one.
Easiest way to verify that it is the compressor being turned off is to simply turn the a/c off yourself while cruising on the highway and see if the air temp changes the same amount as when you floor it. Just press the fan speed button to turn compressor off.
Has it always done this? If still under warranty take it in. I don't notice mine getting hot when accelerating. I have the same truck with 20k miles. Now if your talking about when holding the pedal to the floor, I can't say. I don't really drive like that.
for some reason i cant copy and paste the description and operation of the air delivery system ,it in it says that the PCM disables the a/c for a number of reasons,one of which is 100% throttle ....
Take it in for warrenty. You don't stay in the throttle long enough for it to blow hot air. There is a problem with the programming or a bad actuator. I had my actuator replaced within 10k miles and they had to reprogram.
  • 3 weeks later...
Well I took this truck into the dealer since it is still in warranty, and they said there is absolutely nothing wrong with the A/C. The tech helpfully said that I should expect the a/c air to become slightly warmer when it accelerates. There was another guy there who has a truck like mine and he says his behaves like this also, however he conveniently works for the dealership. I pointed out that I can decelerate for 20 seconds and it is blowing warm air the whole time - apparently this is by design.
I am totally dumfounded - leave it to GM to take a concept that has worked for years and find a way to screw it up. Perhaps I drive the truck too hard - with the 6 speed tranny it seems always to be in too high a gear, so I do accelerate aggressively. The truck manual actually says to floor it if you need to downshift and speed up quickly, but I never accelerate to the point of flooring it.
Now I need to find a way to bypass the connection between acceleration and A/C compressor.
last part.....not happeneing ,,,,computor(s) is in the way
Go back to the dealer and take a brand new truck (not a 2014, a 2013) off the lot that has the same hvac system you have. See if it behaves the same way. If it does not, then ask service manager to take a look at why it is not the same. If they don't have a new one, try a used one off the same lot.
Anytime the dealer tells me something I complain about is normal, I get them to show me it being normal in other vehicles like mine.
This is absolute bull. I have a 2011 and have had no issues, and occasionally I drive my truck at WOT for several minutes at a time. (10 or 15) with the a/c on. Now I cannot attest to whether or not the a/c is disabled, but you certainly should not feel warm or hot air circulating enough to heat you up.
If the dealer is not willing to address the issue, take it higher. Crappy service is just not acceptable.
Funny, mine actually blows colder when I accelerate (not flooring it) but blows warm humid air sometimes when I'm coasting and cools poorly at idle. My 2000's AC was like a blast freezer at all times. I can also hear a slight whistle sound coming from the area of the control head on the dash that changes pitch with RPM......vacuum leak perhaps?
The AC clutch disengages once you reach a certain vacuum lever or throttle position, my 2010 kicks out under WOT and blows warm. Goes back to normal right after coming out of WOT and takes a couple of seconds to cool the vent air back down again.
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
