I am guessing there is still no fix for this issue? I have had the same issue with my 2014 Chevy Silverado Crew Cab LT ever since I hit around 8k miles. I am now at 12k miles and have had my truck in the shop 5 times, at two different dealerships, still not fixed. At the first dealership, my tires were replaced because they were "out of round", my drive-shaft was replaced, checked my alignment and road force balanced my tires. After none of this worked, the dealership concluded that the vibration was within GM's "quality standards" and there was nothing else they could do for me. The second dealership said they had a new "vibration sensing device" that was sent to them by GM to detect issues such as this. After running their tests, they road force balanced my tires and called it a day. This is my 7th GM truck and I have never experienced such a rough and annoying ride quality, this truck drove like a Cadillac when it was first purchased.
Has anyone tried filing Lemon Law for this problem? This will be my next step and if that doesn't work, I will be selling my truck and switching loyalties.
If it rode smooth and now it doesn't it sounds more like a tire issue or the gears in the rear end wearing out of spec prematurely. Keep us posted and its probably easier to get the dealer to buy it back as a trade rather than lemon law. Carmax is a great place to sell I vehicle as well. They quoted me 15k for my 06 z71 with 80k miles on it. Edited by 20Bowtie14
Did the 85mile drive to weekend house, and agree w/ those who have stated hotter temperatures increases vibration. As a reminder, in case Jennifer from GM customer care ever checks back in our now 151 pge post, that my vibration mostly begins at 72-73mph and continues thru 80mph. Does not matter if transmission is in manual mode in 5'th gear, neutral coasting, or in drive and in 6'th gear. 2014 Crew Cab short bed, 6.2 SLT w/ 3.42 gears and Z71. I will add, the more time I spend behind the wheel, now with 5900miles on the truck, the more it feel like this maybe transmission or torque converter related. This transmission just feels so out of sync with the engine and gas pedal, always trying to shift to next higher gear, well before any of us would probably want for real world driving conditions. Transmission feels sloppy to be blunt, especially in around town driving at under 45mph and stop and start conditions. I have had multiple road force balances, new exhaust system which is larger diameter than stock but a GM system which has flapper valve removed, a new driveshaft, and dealer even tried shims in rear leafs to change the pinion angle in rear end, and I use a Range V4 mode disabler. None of which have made any improvement at all in reducing the high speed vibration. I now always drive the truck in manual transmission mode so the transmission is not as annoying. GM why don't you respond to your customers here?
When I took my truck in for the recall on the relocation of the coolant line they also updated the TCM and the ECM. I didn't realize that was a required recall. After they did that my vibration was 10 fold worse. It was tolerable before the reprogramming. My truck has been in for 2 weeks while waiting for and now installation of my new ring and pinion. Getting close to my threshold of toleration. Remember, this is my 2nd truck. About ready to just ask for my money back and go look at Ram or Ford. Getting damn ridiculous.
This is actually really good feedback, because if an adjustment to the Trans control module made the problem worse, then we can surmise that the problem lays within the trans. This would explain why some people have no vibs but we all do...there's no doubt a problem with some of the transmissions GM used, and we happen to have those in our particular trucks. I still have a case open with GM, and on Monday I'm going to ask that they focus on the transmission..particulary the CM, pump, and torque converter. They've been through everything else on mine with no change in symptoms so sooner or later the trans is going to have to be investigated. I hope they replace the whole darn thing so I can actually drive my new truck without that sick feeling I get when I need to get on the highway. I dont even like driving this truck right now, because I feel like there's a failure and breakdown coming my way. This isn't why you purchase a new truck.
Wow. Maybe this is the breakthrough we needed. Has anyone had a transmission replaced as a result of the vibration? I am going to call the dealer who also opened a case with GM on Monday and update him on my vibration, which is only seemingly getting worse, as well as this topic of transmission and torque converter. I just drove home the return 85 mile trip I took on Friday and reported on, and without the rest of the family in the truck all I did the entire rise home was focus on this incredibly annoying vibration. I drove the entire way in manual mode mostly in 5'th gear, even tried 4'th in the 72-80 mph zone and it made no difference. I can now feel more vibration in my steering wheel, my passenger seat makes a noise w/out my wife in it, and even my driver's side mirror now giggles w/ the vibration. See my previous post re suspecting the transmission. GM where are you?
I'm wondering if anyone is having these vibrations issues in the 2015 tahoes or yukons?
Wondering the same thing.....
Sent from my HTC One mini using Tapatalk
I'm seeing everyone with 5.3 and 6.2 with this problem. Any 4.3 guys have it?
Sent from my SM-N900T using Tapatalk
I don't recall, this is a long thread, but has anyone that has a tune installed on their truck have the vibration issue? If the trans and torque converter is a possible cause, then wouldnt it be reasonable that the tune would change these, ie.. Torque lockup and shift points?
Leviblue was thinking same thing. We did have a post regarding someone with the vibration who added slight lift and larger wheels and tires and it DID NOT help the vibration problem. A trans tune would be interesting but if it's a tolerance problem in the trans, wouldn't think changing shift points would matter. I am going to try calling my dealer with open repair on record with GM and report updated feedback and ask specifically about new transmission
Looking for advice. Bought my silverado June 27, 2014. After the first day noticed the shaking/vibration in steering wheel and accelerator pedal. Googled the issue and came upon this forum. I have been following it ever since. My truck now has 1400 miles and has been in the shop twice. 1st service consisted of them saying that two of the Goodyear SRA's were out of round and were replaced. This did not fix the problem. 2nd service consisted of them changing a 3rd tire and replacing all four shocks. This dampened the vibration in the steering wheel considerably, but I am still feeling the shaking in the pedal, center console and other interior parts. The service manager advised me that the second try fixed all issues and that if I was not happy then they were advised to involve the District Manager. I called yesterday to bring it in for another attempt at fixing the vehicle and was told that they would need to contact the district manager before any further work done to the vehicle. After not hearing anything in 24 hours i called back and was advised that they still do not have an answer for me because the district manager is now talking to GM about "what the next plan of action is". Very unhappy with the truck and it seems that they know there is a problem and I am about to get told there is nothing else they can do. 2014 Silverado, crew cab 4x4 LT w/ 5.3 and 3.42 gears.
I can't offer much advice as it seems your dealer has done a ton more for you than what mine has done for me. Mine told me to "wait for a tsb." I am currently looking at other brands and will not ever own another GM.
Edited by M1Tanker
We're so screwed. If GM is not willing to admit this is a problem and help, then we owe it to ourselves to advirtise to as many people as possible thru as many means via internet and thru different forums the truth about this pathetic lack of GM customer support to a address a very obvious mechanical defect. Apparently GM assumes if they ignore us the problem will go away. Total BS as we all bought what was supposed to be the best pickup truck on the market after the updates GM made. Lawyers, lemon law, internet postings. I have only posted once outside of this forum about this. Time to step it up. I hate driving my 2014 GMC Sierra that I spent over $50,000 on.
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
    • There's a bunch of tea leaves that you've read, but in any case the delayed timing is unusual. Not sure how that relates to the rich at idle vs. 'normal' while driving.   If you're in this deep, might be worth investigating, and re-learning the sensor. What have you got to lose? Plus, it properly fixes the timing cover leak.
    • The only problem I have seen this cause is longer crank times.
    • Injector is being sent off today for rebuild and I estimate I'll have it back in 10 days or so.   It may not be the injector...of course...now that I've torn down the intake again. But, let's rule out the injector and replace those spider legs that have been almost rubbed through.   The truck has always had negative timing and I'm reading "normal" timing at warm idle should be +16 or so. I'm negative 16 to 25 or more, and it's always been like that since I bought it.   A light turned on upstairs last night in the old noggin. Rare, I know...   This will be wild, if it turns out to be the cause!   In 2001, according to the old service documentation, the muffler was replaced. Why? I have no idea, it wouldn't have been rusted through by then. But they did a crappy job.   In 2019, another shop replaced it and noted the prior install was poorly done on the work order. "Exhaust system vibrates on crossmember". Except...I guess they just left it be? I believe the husband, the couple who were original owners, had passed by then. Maybe she said it's just not worth it to have the exhaust system fixed and declined repairs. Very few miles were driven between 2019 and 2025.   The exhaust system vibrates heavily on the crossmember and you can feel it and REALLY hear it, even today. Not always, but at idle, it gets going pretty good sometimes.   What if....   ....What if that's enough to trigger one or both of the knock sensors? Could it be tricking the sensors into sensing knock, so it's pulling timing aggressively? Pulling timing heavily means it's firing after the piston reaches full height which means incomplete burn which means the O2 sensor is sensing a rich condition, which means I've been chasing my tail, and what I thought was an inconsequential problem (janky exhaust) has been THE issue for this truck for 25 solid years?   That would be wild. Maybe it IS wild.   The service documentation thereafter, for years, shows visits for rough idle, replacing O2's, replacing the cat, replacing plugs and wires, a misfire condition, like they could never solve the issue. The injector has been replaced 4 times in 80k miles, that's just crazy.   The secondary theory....   The engine has clearly had a leak at the front seal for a very long time (the greasy trench...). I think the truck changed hands quickly ~2025 because there's Napa receipts from someone I don't recognize in the ownership history. They apparently replaced the timing cover seal, and they did a terrible job. There's RTV smeared all over and the leak I had reduced to a weep by snugging the front oil pan bolts is now a leak again.   HOWEVER....I read about replacing the crankshaft position sensor. Any time the ckp sensor is disturbed or timing cover is removed, the truck requires relearning, and that can only be done through a bi-directional scan tool. Skippy with the RTV probably didn't do the relearn procedure is my guess. His scan tool is lost in a pile of RTV goo somewhere.   So, it's very possible the sensor has been disturbed and the truck is just running on the old learn data but not setting a code for anything. The distributor has since been replaced and so has the camshaft position sensor, so all bets are off for that thing.   In the theme of one step forward, two steps back, I returned the accumulator for the AC. The gal I've been working with at O'Really's has been great. She refunded it under manufacturer's defect and we compared it to the replacement I ordered, and sure enough, the replacement is machined very differently (and a gauge actually fits on it!).   Got it home, installed it, started vacuuming it down.... and I couldn't get good vacuum.   The high side service port, where I replaced the old GM ball valve suspecting that was a source of the previous leak....well, I've clearly exposed whatever pre-existing crack in the line where the service port is welded, and made it much worse. Blessing in disguise? Except there goes another $25, now I'm waiting for a replacement AC line.   In 10-ish days ALL the parts will be here. Rebuilt injector, new exhaust system, new cat, new high pressure AC line.   Oh, did I mention the squeaking ISN'T coming from the AC pump? The truck still squeaks when started, and there were words after I started it with the new AC pump installed. But, there was more to replacing the AC pump for just a squeak. A truck with good working AC is something of value, for the comfort alone.   I've ordered a new harmonic balancer because, 30 years is a good run for one of those. Rule it out. The squeak may be something more sinister, though. I'm worried about that ckp sensor and if it was shimmed correctly, or if the timing set was installed correctly. The squeak may be coming from UNDER the timing cover.   At this point, once I get it put back together, I'm thinking I'll take a 50 mile victory lap and then promptly put it up for sale. This truck is cursed. Betty, from beyond the grave, doesn't want anyone messing with her Blazer. Or maybe she's getting revenge for 30 years of shop visits with that thing.
