Pro Comp 1.5" front level only. Bumped the tires up to LT275/65R18's. Overall, likely lost 2-3 MPG's, but I'm much happier with the truck overall.
DSC 1173
You lost that much jumping up a 1/2" in tire size? Truck does look great thou…
So to get the front height the same as the rear do I need a 1.5, 2, or 2.5 level kit. Or does it depend on the manufacture of the kit.
14 LTZ Z71
Edited by 14LTZZ71
14 LTZ Z71
Make sure your truck is on level ground, then measure the distance from the ground to the top of the wheel well... it should be roughly ... Front 37", Rear 39".
That would be a 2" front level. I did a 1.5" because I wanted the front 1/2" lower than the rear. Looks a lot better!!! (but you should measure yours to be sure what you want.)
Mine is 38.5" front, 39" rear...
Edited by Luster
Yours looks great.
Mine is 37 3/16 in the front on both sides, however the right rear is 39 3/4 and the left rear is 40 1/4. Is this because the gas tank is on the left rear?
Below your picture it says you have 2.25 level
Edited by 14LTZZ71
Yours looks great.
Yeah, I need to change that. I bought the Ready Lift, which comes as a 2.25", but you have the option of leaving out a 3/4" spacer that makes it 1.5". I left the spacer out because I wanted 1/2" lower in front..... I'll change my profile description.... thanks!
14 LTZ Z71
The Z71 seems to sit higher in the rear in stock form. It took a 2.5" front spacer to get mine completely level.
Ok, thanks for the info.
Have you had any rubbing now that the components have settled? Even at full lock in reverse? Curious because a really want to run 305 but I don't want any rubbing on a brand new truck. Thanks
I have put 800 miles on the truck now. Still do not rub, full lock, turning, forward or reverse, slight incline etc. It might rub sometime off-roading or something but as of right now, nothing. I am very pleased with my set up!
Finally got the leveling kit installed. I also installed some AMP powersteps with the plug and play kit. It doesn't sit perfectly level though, it's a 2.5" RC kit.
Are you calculating it correctly for the new tire size? or going by the display?
2.5-inch RC leveling kit with only the front kit installed. Stock rear block. Sits really nice and is visually level or just a smidge up in the front... but I like/wanted that look. Tires are 275/70/18s with no rub in any situation.
-12 or +18 offset? Looks great. I'm leaning towards those wheels in black
Mine is finally done! After months of research I went with the RC 2.5" level kit front only, stock rear block.
[url=http://s15.photobucket.com/user/FH212/media/2014%20CHEVY%20Z71/IMG_0862.jpg.html
IMG_0861.jpg[/url]
Does the 2.5 put the fronts CV shafts at a bad angle? Or any level for that matter.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
