Here is a picture of the tire the only one that was not too big I guess. Dumb. 295 70r18 factory rims.
Do you have a 2" level? Any rubbing? Any trimming?
Think these will rub with a 18x9 -12 offset aftermarket wheel?
2" RC level with 305/50r20 terra grapps, rubs sway bar at full lock turning left only. Only have some iPhone pics now, gotta clean her up soon. Can't beat the 305 width though.....97baaf0aa7092704d8b9ba6a2f691eb2_zpsbb955917524251cf4dd48555cf5a13444614_zps06c761d0bb0bd17be6570abee197862a4de8_zps6e03
Looks good. That's probably the tire size I'll go with. How bad did the tires hurt your mileage?
Having a hard time deciding between rcx 2" front level or the whole 2.5" front and rear.
I have 3.08 gears so I won't be going with a big tire and all, but def is slammed into the dirt
I've read a lot of comments about how the 3.08 gears are slow. I have a 14 Sierra with 3.42's and a 07 Suburban with 6.0L, 4speed (4L65e) and 4.10gears. I prefer the 5.3L 6speed 3.42 over the 4 speed 4:10 gears. I put this spreadsheet together to clear the air on this subject because I see how often it comes up.
6L80withAxleGearRatio-FinalDrive_zps6e1c
In summary the 6L80 tranny with 3.08 gears should feel very similar to a the 4L60/4L65 4speed tranny with 4:10 gears!! Gear for gear up to 5th gear for OD ---> Just don't use 6th gear! You still have a better setup than the older 4 speed trucks. The 6 speed and 8 speed transmissions are changing the game when it comes to delivering both power and economy.
Edited by J.Wilhelm
Not sure yet, just got them installed Thursday. Once I burn a tank I can report back, I can tell a difference with light throttle though Edited by hodges25
ImageUploadedByTapatalk1412560442.606932.jpg ImageUploadedByTapatalk1412560467.804339.jpg
3" front, 3/4" in the back. 33x12.5 toyo open country RT.
How do you like those r/t's? Are they pretty quiet?
2.5 rough country lift level. on stock tires so I dont know for sure with that offset. I have a slight rub on the carpeted wheel well but nothing that I am even worried about trimming. I am going to go get the tires rotated early and I might just put a flat screw at the very bottom of the carpet to keep it from even touching at all. its literally a 1/8th of an inch diff. so minor I dont need to do it. I only rub on hard turns backing up or really sharp turns in parking lots. Other than that it is perfect. honestly check the stock offset on the 18 inch rims from gm. if your not incredibly off then when you get the tires have them test fit them. if they dont fit the front or they rub horribly then just dont get them. when I ordered mine I told them upfront that if it was going to rub horribly or not fit right I wast going to a diff. size. sorry for the delayed response I was on an oryx hunt this week.
Hey guys.. sorry if this is a rookie mistake.. Any how-to vids or step by step instructions on the leveling kits? i took a quick glance around and didnt see one. I havent decided which kit I want to go with yet, but I would like to do it myself. (novice in the garage)
thanks, and sorry in advance if i posted in the wrong area. I know how that ruffles "some" feathers :)
Here is two videos that will help anyone who needs it. I installed my Rough Country 2.5'' level myself. It had a spacer on top of the strut and one for the bottom. These videos are on the NNBS sierras and silverados but they are basically the same for the new 2014s. One guy explains his process but is using some other type of leveling kit that involves grinding his bolts which i didn't have to do. The other guy is using rough country's 2'' level on the bottom of the strut which seems the exact same that are being used for the 2014s. Good luck.
anyone running the Bilstein level shocks? They do 0, 1 or 2" from what I read. I hate spacers and aftermarket stuff. 1" Billys have me looking... I need some rake, I use my truck as a truck.
So far I like them. They have a slight humm, but isn't bad at all. With the radio on barely noticeable. Radio off I can talk on the phone or my wife with zero issues.
I installed the rancho quik lifts, so far I am very happy with them, the ride is better.
I just looked up the Rancho Quicklifts and they looked pretty cool. Why wont they work on a Z71?
pulled the rear blocks off my leaf springs to level my denali. looks great and cost nothing. brought the front within 1 inch of the rear and didn't change ride at all.
Do you have any pics of the truck? I was also thinking about just lowering the rear to level out.
I emailed Ranch this AM about the z71 issue. Hopefully it is lawyer speak and it will work.
I was excited about it because the reviews talk about how smooth of a ride they give compared to stock. I sometimes regret getting the Z71 over the standard 4x4 because of the stiff suspension in it. Potholes and speed bumps will jar your bones!
Oh, and do you have to get a new alignment with the quicklifts? I assume you would but not sure.
    • I have never seen GM instructions for the other trucks as per the HD with the 6 speed or the half tons but had got the impression that the HD trucks with the 6 speed were not having the same problem that the 10 speed and pan presented. Also video that I have seen of the HD 10 speed with the gas engine starting in 2024 model year showed that it was a real struggle to even make it work when pulling down hard on the exhaust after undoing the exhaust hanger bracket on the side of the transmission as after all there is little room for the pipe to even go down behind the Y joint as it soon would hit a frame cross member. Also that they had tried just like I did with the gasket off and no way was that pan coming out any way they tried to manipulate the pan. From that as well as the local transmission shop talking about the pain in the rear issue, I was not expecting my pan to come out because GM shows it was not even intended to come out without dealing with the exhaust piping.    It would be nice to claim, here's what you do and its easy to remove the pan guaranteed on any HD truck with the gas 10 speed but dollars to donuts the next guy trying what I did would not have the same luck as the exhaust was just manufactured slightly different and be pissed off at my claim that the pan comes out with no issue. Its more of a try and see if your particular truck might work like mine did .... or not !.
    • Sorry I didn't see this until now, but it works on both the 6 speed and 10 speeds, as well as all the half tons too.
    • Hello, I have a 2018 GMC Sierra 1500 that I recently changed both motor mounts on due to the driver's side being blown out. After replacement I seem to have a steady vibration that I can feel in the pedals and the back of the seat. At this point I'm convinced that the aftermarket "Anchor" branded mounts I used are not performing as well as OE, the only real reason I ended up using the mounts in question was because my local dealers were out a few months to get a Driver's side mount. I've tried "Neutralizing" the mounts according to the motor mount TSB published for these truck to no avail. My trans mount is also in great shape and seems to be absorbing vibrations swimmingly. As far as I can tell there is no issues idling, my idle RPM is steady and I've recently put GM plugs and wires on, however, I have not cleaned the throttle body or intake valves. Any one else have a similar experience with aftermarket mounts? Patience certainly is a virtue that I wish I exercised here. Thank you!
    • I still saw people out for runs, on their bikes/motorcylces, jeeps with the doors off driving around here the past 2 days. I guess we are just used to it here haha.   Tasted like a bonfire the last 2 days.
    • The TCM has to be flashed before it can drive.   If you installed it the way it is, it has the OS (operating system/program) from the 2010 truck you got it from. That will not match with the VIN/OS pair that your 2013 truck has.   You can do the full install. Then tow it to a dealership and they can flash the trucks PCM/TCM with the latest program for your VIN.
